3rd gen Ram TPS
Old Nov 25, 2023 | 02:34 PM
rons prop shop's Avatar
rons prop shop
Default 3rd gen Ram TPS
Hello I am in need of some help
I have a 2003 ram 1500 v8 4.7 with issues with the Throttle body. Sorry for the long post just want to give as much info as possible
My truck started acting up about 5 months ago and gave a P0068 code. My uncle is a Mechanic and I trusted him working on my truck well long story short I shouldn’t have cuz I think he’s mad at me or something lol. I got my truck back and couldn’t believe how much he didn’t care.
My uncle replaced all of these parts and still had the P0068 code
All Spark plugs and coil packs
Some fuel injectors
Both O2 sensors
Camshaft sensor
TPS (Twice)
I have taken everything apart and clean it really good and started replacing everything else I could think would be wrong. But I’m still getting a problem when it’s idle. I haven’t tried to drive it since rebuilding it so I don’t know.
I replaced the valve cover gaskets and when I did I noticed one of the rockers was knocked off. It was the one in the front passenger side. So I changed the lash adjuster and rocker and added assembly lube around the new parts. I painted the valves covers with high temp engine paint so I can see if I have a leak again as well.
The throttle body I cleaned still got the code changed the TPS twice. I removed the throttlebody and bought another one at the junkyard to try and see if it made a difference. I noticed the cruise control cable was damaged (from my uncle) I changed it but it’s not as tight as before. So not sure if I’m supposed to do Something else to make it tight.
I’m the past 2 months I have replaced
The Radiator
The map sensor
The air intake sensor
The PCV valve
The PCV crankcase ventilation filters and vacuum lines
Oil change and changed air and oil filter
With the original throttlebody on now after rebuilding everything, I get a P0121 code and after a minute the truck starts accelerating like I’m holding the gas pedal to the floor With the junkyard throttlebody hooked up I do not get a code, but My check engine light it on, and when in idle it accelerates a little bit. I read online. They said I should try to use a Mopar TPS but when I looked online, they said it was discontinued for a purchase, so I’m not sure if there’s anything else I should do or if anyone else is ran into this problem.
Thank you for any help I can’t tell you how much I appreciate it.
Old Nov 25, 2023 | 07:49 PM
Do you have a scanner that can read live data? If so, just turn the ignition on, and see what the PCM thinks throttle position is, what it thinks manifold pressure is, and pedal position as well. (drive by wire, right?) See if the numbers reflect anything resembling reality.
Old Nov 25, 2023 | 08:44 PM
rons prop shop
Hey thank you for the reply I have a scanner but it’s a cheap one so it doesn’t read live data. But I have been buying everything as I go I have no problem buying a better one if it helps me figure out what’s happening. I’m going to look at getting one now.
Old Nov 26, 2023 | 09:28 AM
Having a good scanner is pretty much a requirement for working on the newer stuff.... Too many computers really complicate matters.....
Old Nov 26, 2023 | 10:14 AM
rons prop shop
I’m gonna buy one to see but my trucks 20 years old I didn’t think it had anything to crazy but I’m gonna get one.
Old Nov 27, 2023 | 05:52 PM
FabricGATOR's Avatar
FabricGATOR
Lets ask this...
Did you (or your uncle) did you do the TB recalibration?
I believe if whenever you remove the TB for cleaning, replace the TB (or TPS) that you are supposed to do a simple procedure with the key and the gas pedal.
Please let us know what you end up doing to get your truck running again.
Remember it worked great when it left the factory...
