2005 RAM Diesel - steady/fast clicking from Intake Heater Grid area
Old Nov 25, 2023 | 07:22 PM
riderboy1961's Avatar
riderboy1961
Default 2005 RAM Diesel - steady/fast clicking from Intake Heater Grid area
Good Afternoon;
Been working on this truck lately and discovering some things here and there but not familiar with the 3rd Gen RAM Diesel
I open the hood, turn the ignition key to the ON position, a fast clicking noise starts from very near the Intake Heater Grid. I am not positive that the clicking is coming from it but with my head over the engine and moving side to side, front to back, the clicking seems to be coming from it of very near it - the 2 Heater Grid "Relays" do Not make any sound, the clicking is Not coming from the Relays.
So I did a self test on the clicking..... if I just leave the key in the ON position the clicking sound will just keep on clicking, it Never stops even for about 5 minutes straight, until I turn the ignition key back off, then of course the clicking stops.
QUESTION:
*** "Is This Normal for these trucks?"
*I am concerned that the clicking should stop at some point or eventually something will burn up?
Thank You
Old Nov 25, 2023 | 07:50 PM
What else is up there that might be clicking? I would expect, that if you actually start the engine, it stops??
Old Nov 27, 2023 | 12:52 AM
Prismatic's Avatar
Prismatic
Originally Posted by riderboy1961
Good Afternoon;
QUESTION:
Thank You
Clicking could be arcing actually, check this video
Edit - Just saw you have a 2005, not sure the same applies.
Old Nov 28, 2023 | 09:14 PM
riderboy1961
I checked with my friend who has an 06 2500 diesel, his does the exact same thing. Apparently this may be normal, I dont know. It just doesnt seem right though.
I had codes for the heather Relays but those codes went away when I found the front right headlight housing Ground issue and cleaned the contacts there and re-tightened the ground bolt on the inside right fender.
I guess Ground issues can cause many different problems that I would not associate to a Ground using what common sense I still have.
Anyway..... Currently the truck is Good!!
Old Nov 29, 2023 | 02:17 AM
Prismatic's Avatar
Prismatic
Nah it's totaled you should trade titles with me, ill take it off your hands
