P1501 code, no ABS light but cruise control not working
on
Do you have four ABS. Or RWAL ABS. That means sensors at the front and rear or Just at the rear. If you have a scanner that can read ABS, you can jack up the truck with jack stands under it. Rotate each tire and read the RPM numbers. If you have zero at one wheel. You found the cause. Next step is to find out if you have a open wire or sensor. I have had Clock springs cause the same problem and also cause the vehicle to pull when driving.
