2007 Dodge Ram 1500 / Transmission Replaced or Original?
Old Feb 25, 2024 | 08:47 PM
lisaromero88's Avatar
lisaromero88
Default 2007 Dodge Ram 1500 / Transmission Replaced or Original?
Hello everyone, my name is Lisa. New member 👏🏼🎉 I have a 2007 Dodge Ram 1500, I need to confirm if the transmission that it has is the original or if it was replaced. The code that the transmission is showing is the following: 337720293P52119494AG. I’m in doubt because the transmission code does not match with the VIN I’m not sure if it’s needs to match the VIN number or not. Thanks
Old Feb 26, 2024 | 08:53 AM
part number comes back as fitting 05 to 08 Ram 1500..... So, its the correct trans for the application, now, is it the original trans? I doubt you will be able to determine that.
is there a problem with the trans?
Old Feb 27, 2024 | 08:19 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
No way to determine that unless you can tell that fasteners have been disturbed (i.e. bellhousing bolts, mount fasteners, etc).
