New 40 series muffler help
Old Jan 9, 2006 | 08:04 PM
Sandstone's Avatar
Sandstone
Default New 40 series muffler help
Hi guys, you have given me good info before and im sure you can do it again.. im up to changing the muffler on my ram cuz i need ameaner sound and i have decided on a flowmaster 40 series.. i went to buy it on e-bay then i noticed that there were different sizes
they had 3" o/o
2.25 o/o
2.25 o/c
i dont know what any of that means.. im not too car savy... i have a 2005 dodge ram hemi quad cab short bed.. is ther any one i should get.. do you guys know exactly what i need???? i appreciate the help... thanks
Old Jan 9, 2006 | 09:02 PM
05hemi's Avatar
05hemi
Default RE: New 40 series muffler help
Well since your stock exhaust pipe is 3" you will probably want the muffler with the 3" inlet and outlet. The o/o and o/c stands for offset/offset and offset/center relative to the inlets and outlets. On mine it's 3"c/o which just means that the inlet pipe is in the center and the outlet pipe is offcenter. I'm not sure, but from what I understand the performance should be the same regardless of whether or not the pipes are center or offset. Hope this helps.
Old Jan 9, 2006 | 09:20 PM
Sandstone's Avatar
Sandstone
it does help... thank you
Old Jan 9, 2006 | 11:17 PM
Verano's Avatar
Verano
I also have an 05 1500 hemi with the 40 series flowmaster and I have the 2.5" pipes. It sounds great. I asked the shop that installed it about using 3" and he said that since I am not running true duals that I dont need 3". So I woulld say the 2.5" are just fine, thats what I have and I am very happy with the sound I get from it.
Old Jan 10, 2006 | 02:35 AM
sandiegohemi's Avatar
sandiegohemi
I have an 04 Hemi, and ran 3" single out. Lost low end torque. I'd recommend 2 1/2" single out or 2 1/4" dual out. I changed to the dual with the smaller pipe and got the low end back. I have a 40 series delta flow.
sandiegohemi
Old Jan 10, 2006 | 06:03 PM
motorhead426's Avatar
motorhead426
Just to clarify for the the guy who started the post.... you mean, your running "2" 2.5" outlets, not one 2.5" outlet. I'm guessing the shop told you that you don't need "2" 3" outlets without true dual exhaust. So you and the shop are correct in that regard. As for me, I'm still pondering how to mount true duals..... Any of you guys have any pics of true duals on a 4x4 QC?
Old Jan 11, 2006 | 01:09 PM
eltupac's Avatar
eltupac
I have a V6 and the pipe coming into the stock muffler is 2.5. I had a 2.5 inlet 40 series and fit perfectly to the cat pipe. I dont know about the V8s.
Old Jan 11, 2006 | 04:19 PM
silvernightmare's Avatar
silvernightmare
I have the super 40 flow master #9530452 (3" in 2.5" dual out). The sound could not be meaner. Feels and sounds great, I think I can feel a little something along the lines of performance gains. I had a buddy of mine use mandrel bent pipe to complete the duals. Could not be happier.
