O4 Cummins lope at idle
If the cam & crank sensors have not been changed, swap them. They are cheap & they do not last forever. Do not get anything but Cummins parts on these sensors (same sensor, 2 locations). Last time I swapped mine it was an eye opener, my tuning was dialed in for how the motor ran (self tuned) and on the 1st stab of NTK sensors, thru a code right away and the motor did not run 100% like it did with the old sensors. Got Cummins parts and did a comparison of the magnets at the sensor end & the NTKs had a weak magnet compared to the Cummins sensor. Not sure who makes that sensor but back then it was under $30 at the Cummins parts shop.
In the issue I had with the lope...
edit: Found the thread and it is the opposite of yours... was rock solid until the 5 min mark & then had a rough idle. If you want to read it search for "Rough idle after 5 minutes" & steve05ram360 & you should find it, again it was the opposite of your symptoms. Rough idle after 5 minutes.
I'll get them ordered tonight so just 2 of the same sensors?
https://www.thoroughbreddiesel.com/cummins-crank-cam-position-sensor-03-18-dodge/?utm_source=google&utm_medium=cpc&utm_campaign=%28 ROI%29%20Shopping%3A%20PMax%20-%20Everything%20Else%20%7C%20Low%20AOV&utm_id=1775 4572369&utm_content=&utm_term=&gad_source=1&gad_ca mpaignid=17347656857&gbraid=0AAAAAD-Q2AvkGs59ppE0tAEQ5PU8RORad&gclid=CjwKCAiAs4HMBhBJE iwACrfNZWForFLZ89aYUDgIbTBYSFV4pl7D9AoXgEweAswmttF oXT6mph4M-RoCie0QAvD_BwE#tab-shopperapprovedreviews
https://www.thoroughbreddiesel.com/c...pprovedreviews
Hey got busy this weekend so wasn't able to get it on yet from what I've researched it's behind the computer, but something to note today when I cranked the truck I let it idle for about 10 minutes and went and checked the smarty low voltage at lift pump code well I cut the truck off and cleared code and it idled perfectly so what is y'all's opinion on that?
