O4 Cummins lope at idle
Old Mar 2, 2026 | 08:22 AM
  #61
dodgetruck2's Avatar
dodgetruck2
Originally Posted by Goshdarnram
Oh okay makes sense I will get it checked out absolutely, I'm starting to believe it has to be an injector issue, truck runs fine when warm I would just rather find the issue before something negative happens
its not a fool proof theory but if you're not hazing smoke or anything when warm, the possibility of damage is minimal
Old Mar 7, 2026 | 09:49 AM
  #62
Goshdarnram's Avatar
Goshdarnram
All tested between .4 and .6
Old Mar 7, 2026 | 10:18 AM
  #63
Isn't that a bit low??? Aren't they supposed to be around 12 ohms or so?? (we are talking about injector resistance here, right?)
Old Mar 7, 2026 | 10:57 AM
  #64
Goshdarnram
From what I've read anything lower the 1.0ohm is good to go truck was off when doing readings
Old Mar 7, 2026 | 11:02 AM
  #65
Goshdarnram
I just took the cover off and probed the 2 prongs on the injectors them selfs for some reason there was oil in the plug ins to the injectors not sure if that's normal or not but did notice that
Today it didn't lope wonder if it's because it's like 80
Old Apr 9, 2026 | 03:41 AM
  #66
Goshdarnram
Default Anyway this could be the culprit oil in connecters on all 3
Old Apr 9, 2026 | 08:02 AM
  #67
dodgetruck2
I wouldn't be overly concerned buy it, new injector harness wouldn't be the worst investment though
Old Apr 9, 2026 | 08:40 AM
  #68
Goshdarnram
It's starting to lope more even when warm and throwing a fan clutch speed code now
Old Apr 9, 2026 | 09:12 AM
  #69
The fan code may be a result of the lope......
Old Apr 9, 2026 | 09:25 AM
  #70
Goshdarnram
That's what I was reading on people saying
