33s on a stock truck?
Old Feb 4, 2006 | 03:28 PM
IshouldaGOTtheHEMI's Avatar
IshouldaGOTtheHEMI
Default 33s on a stock truck?
i was wondering if i could stick 33s on a stock 05 1500 4x4 by MAYBE cranking the torsion bars?
i tried searching, if anyone has posted this before and came up with no results. any help would be great. thanks!
Old Feb 4, 2006 | 03:40 PM
motorhead426's Avatar
motorhead426
Default RE: 33s on a stock truck?
Yeah they'll fit. Some guys on here have 35's on their trucks without cranking the bars. If you have the stock 265/70R17's like me, and do a little math, they are 32" tires. And those have a lot of room as it is. So, yes 33's will fit without a problem. I'm actually going to mount some 35's once I buy some fender flares. I think the flares will make it look better with the wider tire.
Old Feb 4, 2006 | 04:26 PM
IshouldaGOTtheHEMI
sweet, for some reason, i thought we had 30s but thanks.
so 35 swill fit to ey?hmmm sounds like a good idea! will they rub at all?
Old Feb 4, 2006 | 05:40 PM
Saint's Avatar
Saint
As far as 33s go the factory 275/65/20s are a 33" tire. The 35s will have a slight rub on the sway bar I believe, but nothing too serious, and every truck is different so while somebody was able to get away with 35s without cranking the T-Bars, yoursmay require slight cranking.
Old Feb 5, 2006 | 06:03 AM
justint420's Avatar
justint420
Excuse my ignorance but could someone tell me some more info. on cranking the torsion bars? Also what kind of 33 is out there to fit a 17in rim? And lastly is really ok to put a 35in tire on my truck stock? I was told 285/70/17 was the biggest I could go, and If my math is correct a 35in is much bigger than that. Could someone clear up this stuff for me? Thanks
Old Feb 5, 2006 | 06:28 PM
Saint's Avatar
Saint
A 285/70/17 is a 33, and is the most popular size for a 17 inch rim.
To crank the torsion bars, you just turn the adjusting bolts on the torsion bar bracket, right to go up, left to go down, it's easiest to jack up the front end and get the front tires off the ground.
A 35 really fills up the fender on a stock truck, but it does fit, a 315/70/17 is a 35 and fits a little bit better then a 35x12.50R17.
Old Feb 6, 2006 | 03:46 PM
motorhead426
I haven't seen too many people refer to tire size calculators on this forum, but I've been using these 2 links for a while. One gives you a neat lil pic (LOL) of how much different two tires are to each other....
http://www.miata.net/garage/tirecalcold.html
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Hope this helps!
Old Feb 6, 2006 | 08:53 PM
justint420's Avatar
justint420
What advantages/disadvantages are there to turning the torsion bars?
Is there a cheaper way to recalculate the speedo other than a superchip?
Old Feb 6, 2006 | 10:13 PM
Saint's Avatar
Saint
The advantages are that you get more clearance for bigger tires and can level out the truck. Disadvantages are that if you aren't careful, and you over crank the torsion bars the CV shafts can drop out of the differential, but I've only heard of one person doing that, and they did it after they put a lift kit on their truck.
If you have the Rotations per Mile number of the tire then the dealership can recalibrate your speedo, it will cost you about $90.
Old Feb 7, 2006 | 02:25 AM
2002ramon24s's Avatar
2002ramon24s
this is going to sound funny but i have a 33 inch tire on my lowered 02 2wd ram. i have a 315 35 24 tire it is a 33 inch tall 12.4 wide tire. well no rubbing with a 2x4 so if u cant put 33s on maybe even 35s on a stock 4x4 im sorta worried. (ignore me im bored)
