Problem with turn signals
Old May 10, 2006 | 04:16 PM
hmipwrd's Avatar
hmipwrd
Default Problem with turn signals
Sometimes they work and sometimes they don't. Sometimes when i flip for the left the left turn signal the right one comes on instead, and vise versa. has anyone had a problme like this? Could it be the bulbs are something more seriuos. thanks in advance for any suggestions.
Old May 10, 2006 | 04:44 PM
nos4fuel's Avatar
nos4fuel
Default RE: Problem with turn signals
try checking your fuses, and it may be your wiring harness
Old May 10, 2006 | 07:38 PM
srenken's Avatar
srenken
What aftermarket items have been installed? Trailer tow circuits are separate from truck's brake and tail lamps. Someone has to have gone mucking with the wiring to make that happen. Is it only in the back or does the front do it as well? If everything is stock, then look at the silver module mounted to the fuse block. That module is programmable based on installed equipment, so your dealer or someone in the know will have to set it up for your vehicle configuration if that is what is found wrong.
Old May 10, 2006 | 10:38 PM
Hemi_Chris's Avatar
Hemi_Chris
Ha, this exact same symptom happened with my '03 Quad Cab also. I was on the brink of taking it in to a dealer when it just stopped doing it.
One thing I noticed was that if the tilt wheel were unlocked, raised to its highest position, then lowered again the problem went away. Seems like some sort of wiring fault in the steering column to me. But then again, I haven't had the problem again in a couple months.
Old May 11, 2006 | 01:25 AM
hmipwrd's Avatar
hmipwrd
It just started happening the last few weeks, i put aftermarket taillights on last sept. and the wiring harness (for trailer) is factory. It wont do it all the the but it's becoming alot more frequent. I suppose i could be like most of the other in my town and just stop using the turn signals all together, but then again, why?
Old May 12, 2006 | 03:08 PM
Beachesguy's Avatar
Beachesguy
My turn signals failed in my '04....rust in the wiring harness supposedly. I would put the left turn signal on and my hazards would flash. Intermittently, OF COURSE. Right signal was fine. Replaced under warranty. Took them 2 days to figure it out.
Old May 12, 2006 | 04:40 PM
mill540's Avatar
mill540
Low blinker fluid?
Old May 13, 2006 | 03:42 PM
Johndcjr1989's Avatar
Johndcjr1989
my dad had the same problem on his 03 ram he took it to the dealer and it was just bad wiring.
Old May 14, 2006 | 06:24 PM
parkersdropped03's Avatar
parkersdropped03
Mine did the same thing. There is a circuit board mounted to the back of the tail light. It will have to be replaced. I had it repaired under warranty.
