I might be racing tonight! What time can I expect?
Old May 26, 2006 | 05:37 PM
rob[GL]'s Avatar
rob[GL]
Default I might be racing tonight! What time can I expect?
So, the weather is kind of ****ty here today, 50 degrees outside... But the rain has stopped. And assuming that the rain does not come back, there is a sponsored street-legal drag racing night tonight just outside of the city at our Castrol Raceway...
Most of you know my truck already, it's a 2005 Dodge RAM 1500 HEMI SLT/LARAMIE 4x4 Quad Cab. I'll be running 91 octane, about 1/2 full... I have my resonator and muffler removed, and I have a K&N filter. I run the 3.92 gears with 20" rims with racing tires... I do not have a superchip or anything yet...
Should I run in 4-HI?
Should I run with tow-haul mode on?
Should I bother removing the spare tire?
I've never been to the track before, so I'm really exicted and I want to prepare as much as possible (weather permitting of course).
Old May 26, 2006 | 06:18 PM
RedSS454's Avatar
RedSS454
Default RE: I might be racing tonight! What time can I expect?
ORIGINAL: rob[GL]
Racing tires? Like slicks or drag radials? What kind and brand?
ORIGINAL: rob[GL] Should I run in 4-HI?
No, the 2wd is fine and if you go that fast in 4-Hi, your truck will not appreciate it.
ORIGINAL: rob[GL]
I have heard people say this is supposed to make you faster, but I ran with it once and the difference was negligble. But, thats just my $.02.
ORIGINAL: rob[GL]
No, the weight won't make that much of a difference anyway. Way more work then results.
My guess would be high mid 15's until you get the tree figured out, then low 15's MAYBE a 14.9X
Chris
Old May 26, 2006 | 06:26 PM
20brewcity02's Avatar
20brewcity02
figuring out the tree will not improve your time, just r/t that has noting to do with your e/t
Old May 26, 2006 | 07:25 PM
rob[GL]'s Avatar
rob[GL]
ORIGINAL: RedSS454
http://www.hankooktire.ca/product/ti...tail.asp?pid=9
Old May 27, 2006 | 12:16 AM
RedSS454's Avatar
RedSS454
ORIGINAL: 20brewcity02
True, but I should have elaborated. If you figure out how to launch hard without red-lighting, that will help. Brewcity is right, your R/t won't necessarily improve, but your 60 ft and overall time will if you launch hard.
Chris
Old May 27, 2006 | 12:18 AM
RedSS454's Avatar
RedSS454
ORIGINAL: rob[GL]
ORIGINAL: RedSS454
I guess those have more bite then a normal tire, but I wouldn't consider them racing tires. Make sure to get some heat in them, drive around the water box and spin them a few times. No need to be John Force or anything. Driving around the water box prevents water from being flung up into the fenders and later dripping back down. I can't imaging having too much traction issues unless you leave to hard.
Chris
Old May 27, 2006 | 03:24 AM
rob[GL]'s Avatar
rob[GL]
Well, I just got back, I was there for 2 hours, and raced a total of 21 times...
I sucked at first, with the worst 1/4 mile time of over 17 seconds, however, after about my first 3 runs, I was running 16.2 all night long, my final run was as follows;
R/T: .365
60': 2.369
330:6.747
1/8: 10.396
MPH: 67.96
1000: 13.504
1/4: 16.178
MPH: 83.71
Stock 2005 Dodge RAM 1500 Quad Cab HEMI 4x4
20"s
Old May 27, 2006 | 11:05 AM
kenihemi's Avatar
kenihemi
Yup, about what I expected. Mostly stock 4x4 qc's run in the low to high 16's.
Old May 27, 2006 | 04:02 PM
rob[GL]'s Avatar
rob[GL]
I really wish I had the $$ for one of those STS turbo's...
Old May 27, 2006 | 04:20 PM
Nicky B's Avatar
Nicky B
ORIGINAL: rob[GL]
Well you could really get your times down with headers and cam's. A cam alone can add 50HP. You could get into the low 14's before you would need anything like a power adder.
