Chip vs intake
Old Jun 9, 2006 | 05:44 PM
JWMazur's Avatar
JWMazur
Default Chip vs intake
I just got a 2005 Dodge Ram 1500 Daytona edition, and I was wondering which upgrade is the best bang for your buck? I plan on eventually getting a supercharger, but right now my budget is limited.
Thanks,
Jared
Old Jun 9, 2006 | 05:47 PM
boyd98's Avatar
boyd98
Default RE: Chip vs intake
programmer if you are going to use 91 or 93 octane gase - CAI if you are going to use 87 octane
thats just my thought - i had a rep from superchips tell me that unless you use the higher octane gas you will not get HP gains; ill provide the email if needed
Boyd
Old Jun 9, 2006 | 06:10 PM
truckin151's Avatar
truckin151
there are 3 settings on the flashpaq:87 octane economy,91 octane towing and 91 octane performance. The 87 octane economy will make your truck run smoother and shift better and improves your gas mileage, The 91 octane towing will increase your torque for towing, and the 91 octane performance gives you the high horse power and performance. Also you can adjust your shift settings and alot of other little things too and its easy to use and tune your truck to what you want to use it for. So basically you can have it set to the 87 for now cause of the rediculouse prices of gas and then switch the settings whenever you feel an itch to give you more power and use the 91. Im getting my exhaust put on this weekend and then shortly after I'll be getting a chip and then the CAI.
Old Jun 9, 2006 | 06:21 PM
JWMazur's Avatar
JWMazur
I use 91 octane now, so i dont see that being a problem
Old Jun 9, 2006 | 06:31 PM
boyd98's Avatar
boyd98
If your using 91 now - i'd definately get the programmer before the CAI. The CAI will probably give you a better sound, but the chip will give you more performance
If you get the programmer, let me know how you like it, im up in the air about it now.
Thanks,
Boyd
Old Jun 9, 2006 | 06:32 PM
JWMazur's Avatar
JWMazur
now that i decided on a programer, which one?
Old Jun 9, 2006 | 06:33 PM
truckin151's Avatar
truckin151
Then go for the chip, you'll be much happier
Old Jun 9, 2006 | 09:39 PM
boyd98's Avatar
boyd98
everyone on these forums i have seen likes the superchip 3815.
Old Jun 9, 2006 | 09:56 PM
20brewcity02's Avatar
20brewcity02
3715 is for the 2003 and earlier v8s correct? 4.7 5.2 and 5.9?
Old Jun 10, 2006 | 06:31 PM
moparman05's Avatar
moparman05
I'd go with the chip. But some chip and programmers are for those guys who have already done intake and exhaust. The chip just helps maximize what the intake and exhaust are doing already. Chip will definetly get you more HP than intake. And if your planning on a SC in the future, why waste money on an intake you'll have to replace or modify for the SC.
Just my 2 cents!
