rear diff oil type and amount
Old Jun 30, 2006 | 10:16 AM
stump_breaker's Avatar
stump_breaker
Default rear diff oil type and amount
I don't have access to my OM. Can someone type in the weight and amount of rear diff oil for the Chrysler 9.25 (05 Ram 1500)? Got to go get some for the new 4:56's today. Thanks......
Old Jun 30, 2006 | 10:45 AM
LoFlyer's Avatar
LoFlyer
Default RE: rear diff oil type and amount
75-140 synthetic. Amount is 77oz but fill to 1/4 inch below fill hole on level ground. Recheck oil level after test drive as the axle contains some oil.
Old Jun 30, 2006 | 12:19 PM
Drew's Avatar
Drew
actualy, if you dont tow anything, 75-90 synth. will do better
Old Jun 30, 2006 | 02:52 PM
stump_breaker
Nope, I tow. Thanks guys....
Old Jun 30, 2006 | 04:18 PM
osteodoc08's Avatar
osteodoc08
If you check the Sunday papers, you can sometimes find an auto parts store that has the Mobil 1 on sale. I didn't find any on sale when I changed mine out and it was like $50 for everything (oil, gasket stuff, etc)
Old Jun 30, 2006 | 06:05 PM
LoFlyer's Avatar
LoFlyer
Drew, what's the advantage to 75-90 if you don't tow?
Old Jun 30, 2006 | 06:51 PM
osteodoc08's Avatar
osteodoc08
ORIGINAL: LoFlyer
It's usually cheaper, easier to find, and possibly give you better MPG. I just stuck with the factory recommended weight when I changed out my fluid. Personally, I like the heavier fluid. Might possible cut down an gear whine as well. At least that is what Ford did when they were having gear whine in thier IRS SUV's, especially the Explorers.
Old Jun 30, 2006 | 08:35 PM
motorhead426's Avatar
motorhead426
I just bought fluid for mine, and it cost me $60. The $60 includes 2 quart's for the front and 3 qaurt's for the rear as I added a PML diff. cover to my rear axle that holds 3 quarts. Did I mention I used Royal Purple with includes the Limited slip additive already in the bottle. I thought $60 wasn't too bad.
Old Jun 30, 2006 | 08:58 PM
Drew's Avatar
Drew
90 also gives less rolling resistance than 140
but since you tow alot 140 would be the better route.
