custom sub box, UPDATED
Old Jul 18, 2006 | 07:46 PM
  #21
Memaxie's Avatar
Memaxie
Default RE: custom sub box
That enclosure looks great!! Sounds like alot of work though. I found a sub box for my 2005 SLT 1500 4X4 on ebay for $47.00. I could not believe the price. I also found 2 10 inch Audiobahn subs for $47.00 also. I had already installed my system with one 4 channel Alpine amp running my highs, and another amp to run the subs. Man, does that Ram sound good. So, if you guys are handy with the tools, build it and they will come, but some of us arent that crafty. Good luck to all!!
Old Jul 26, 2006 | 02:57 AM
  #22
phatstrat96's Avatar
phatstrat96
Default RE: custom sub box, UPDATED
HOw did you hook up your amp throught your head unit without using a aftermarket head unit. I am excitied to hook up my subs in my 04
Old Jul 27, 2006 | 07:06 PM
  #23
1swtbrz's Avatar
1swtbrz
theres a part you can buy at best buy or any place that does installs that you tap into the speaker wires and it allows you to hook up the rca cables. i will say that it doesnt sound that great cause you cant fine tune it and i am going to get a new deck
Old Jul 27, 2006 | 07:12 PM
  #24
nathanp's Avatar
nathanp
ORIGINAL: 1swtbrz
If you get a mono block sub amp, you can do the fine tuning with the amp and then just get a cross-over to eliminate all the treb and mid. Thats all i did and mine sounds better then when i had an aftermarket deck i think.
Old Jul 28, 2006 | 08:06 AM
  #25
habeba86's Avatar
habeba86
Most amps should have a built in low-pass filter.
Old Jul 28, 2006 | 01:10 PM
  #26
CaptainPioneer's Avatar
CaptainPioneer
nice job looks good definitely a good job on the Vinyl work... Now where the subs are actually housed? Did u fiberglass a mold to go in there so that it is completely sealed? Or is your subs just sitting in an open area surrounded by Sheet metal? Im curious to know cause i didnt see any pictures of the interior of the enclosure
Old Aug 2, 2006 | 12:28 AM
  #27
tommygun89's Avatar
tommygun89
any problems when someone sits in the backseat?
Old Aug 3, 2006 | 04:51 PM
  #28
1swtbrz's Avatar
1swtbrz
not at all
Old Feb 19, 2007 | 01:01 AM
  #29
Stroker's Avatar
Stroker
Ok I,m damn slow but I just bought an amp and the mdf to build this but I noticed there will be a gap around wher the bolts are. Did you seal that off or jus use washers there to keep it flat?
