AIR RAID M.I.T.
Old Jul 20, 2006 | 03:01 PM
stickshiftsrule's Avatar
stickshiftsrule
Default RE: AIR RAID M.I.T.
ORIGINAL: Squirrel508
I meant to say 68.50mm I guess I had a brain fart... Oh Well the price is 180 plus 80 core charge? Do you think that the tb and mit together will complement each other?
I "think" so, but cannot say for certain.
In order, I did;
Magnaflow 3" exhaust (dumped) -noticable power increase
Airaid MIT -increase (if any) was not really noticable
Airam jet stream scoop + power wire -no noticable difference at first.
....But, after a week with the power wire I took it off, performance dropped immediatly.
So apparently the wire is one of those gradual change mods......But it does work.
Fastman 68.5mm TB -noticable power increase
I recently insulated my MIT and airbox. I also replaced the airaid coupler with a 3" plumbing quik-connent (smoother).
I drilled a hole in the new coupler and mounted my IAT sensor in it. And I modified the airbox snorkel by adding a small scoop to the end of it to better "catch" the air being directed in by the airram scoop.
-the result is another noticable power increase. And improved MPG, IF you can keep your foot out of it.......
.......yeah right.......[sm=gears.gif]
