Cant spin tires, even by power braking...
Old Aug 12, 2006 | 03:53 AM
Dire Wolf's Avatar
Dire Wolf
Default Cant spin tires, even by power braking...
Is this normal? I know because of the Limited-Slip it wont spin just stomping on it but I tried to power brake it with some buddies in the truck and nothing! ??????
Old Aug 12, 2006 | 01:43 PM
RedSS454's Avatar
RedSS454
Default RE: Cant spin tires, even by power braking...
I don't think that's normal. I don't have the LSD, but on dry pavement if I stomp on it I can chirp the tire, and powerbraking is easy. Not sure about you though.
Chris
Old Aug 12, 2006 | 02:45 PM
Nicky B's Avatar
Nicky B
Are you sure your not in 4X4 when you try to power brake.
Old Aug 12, 2006 | 04:03 PM
Dire Wolf's Avatar
Dire Wolf
ORIGINAL: Nicky B
Nope
Old Aug 12, 2006 | 04:16 PM
DonG's Avatar
DonG
I don't think there is anything wrong with your truck. Mine won't do it either and I saw in another similar thread, most won't. When I try to power brake the torque management really kicks in and limits the rpms. In most instances, it will chirp them pretty good from a rolling start though.
Old Aug 12, 2006 | 04:30 PM
06REDRAM's Avatar
06REDRAM
TRY IT ON A WET SURFACE. ON DRY PAVEMENT YOU MAY HAVE A GOOD GRIP. I HAVE TROUBLE SOMETIMES.
Old Aug 12, 2006 | 04:48 PM
kenihemi's Avatar
kenihemi
On dry ground a heavy 4X4 QC cannot spin the tires without some serious power adders, even in 2WD mode.
Especially when you have some buds in it too, just makes it heavier.
A power brake to around 2000rpm's should do it, but don't. Its really hard on the brakes/drivetrain.
Old Aug 12, 2006 | 09:28 PM
Stroker's Avatar
Stroker
Thats funny I can hardly keep from spinning mine.
tamuccmike's Avatar
tamuccmike
well i have an 05 RC 2 wheel drive...but...i would think with a hemi (i assume you have a hemi, even a 4.7 should be able to) BUT i also had a similar problem, after the truck has some miles on it and the tires wear a little you should be able to spin them really well, seems weird but on my truck it spins them hardcore now especially when it's over 95 outside, i think it's the heat from the road...if your 06 is like my 05 just let it break in and wait for the tires to wear slightly...you should be able to (i had a 93 gmc sierras with max 240 hp and i could spin them, but our trucks have the tm too.) good luck!
Old Aug 12, 2006 | 10:33 PM
kenihemi's Avatar
kenihemi
You guys with RC, 2WD trucks make me laugh when you try to compare your light weight trucks against our big school buses.
I am always willing to let you up against our 2WD, RC Camaro.
But, why do you even post on these threads? To make you feel better, that's why. Go post on a mustang site and tell them how fast you are and how you can really, really spin the tires, LOL!
Real people are smart enough to know the difference.
