Reving limits!
Old Sep 18, 2006 | 12:08 AM
sizzle01's Avatar
sizzle01
Default Reving limits!
I have a 2003 dodge hemi 5.7 an i can only rev it up to 4,000rpms........is this standard on all dodges?....strange...my buddy has a nissan titan an it got up before my truck did...Hemi VS nissan not suppeosed to happen...if anyone may know somn about this....please write back or email me @ mrbains01@aol.com...thanks....
[IMG]local://upfiles/43068/87D1A358287343139077A7224B503C78.jpg[/IMG]
Old Sep 18, 2006 | 01:02 AM
hemistyle's Avatar
hemistyle
Default RE: Reving limits!
Well my 04 was 5800 stock. With the FlashPaq i'm at 6100.
Old Sep 18, 2006 | 01:56 AM
schnydz's Avatar
schnydz
My truck turns to 5500 if I stand on it and let the tranny do it's thing. If I hold the gears manually, I can get 6000 no problem.
Old Sep 18, 2006 | 05:27 AM
angusdevil's Avatar
angusdevil
I've read around here that some of the earlier 3rd gen's will only rev up to 3900 or 4000 when you are in Park. As for when you are in gear or neutral, I can't vouch for that but I have seen the same on my 04.
Old Sep 18, 2006 | 09:28 AM
abarmby's Avatar
abarmby
Yep me too.
On my 03, you can only rev it to about 4000 max while in park.
However, It's not a good thing to do I'm led to believe, to rev your engine while under no load.
Something about rotating masses and G forces etc?
Old Sep 18, 2006 | 12:12 PM
Mikec714's Avatar
Mikec714
ORIGINAL: angusdevil
today while coming back from work i was doing a steady 40 MPH around 1500-2000 RPM's, i stood on it and it rev to almost 5500, then i let off so it can shift, got up to 70 MPH, lol damn i love my hemi
Old Sep 18, 2006 | 12:38 PM
truckin151's Avatar
truckin151
When I'd floor my 05' HEMI from a dead stop it would usually hit around 5500+/- and just reving it in nuetral or parked to show off my exhaust a little it will hit roughly 3500-4000rpm before I back off my foot to let it come back down. There's really no need to go over that because for the exhaustt on my truck hits every tone up to that rpm range and doesn't sound good after that range. Plus I've also heard that its not good for the engine to rev that high or higher for a long period of time too so Ive never tested it out really, dont want to blow anything
Old Sep 18, 2006 | 03:21 PM
sizzle01's Avatar
sizzle01
thanks for all the answers guys.....[&:]
[IMG]local://upfiles/43068/E116F76896234CBD8C2C266806D390A9.gif[/IMG]
Old Sep 22, 2006 | 01:23 AM
motorhead426's Avatar
motorhead426
The 4000rpm rev limit in park or neutral is normal. It's to help keep the engine from unnesseccary RPM's when there is no load present, just like what abarmby was talking about. The shift point when in gear should be 5700 RPM stock. If you put your truck in a manual gear, and floor it, the truck should get up to the rev limiter and hold there.... got to love throttle by wire!!
Old Sep 25, 2006 | 03:33 AM
Max00racer's Avatar
Max00racer
yeap same for me in my 03' hemi. Park or neutral you cant get above 4 grand. Rev it out and you get around 5700-5800. Its a good idea so you dont damage anything accidentally in park or neutral with no load on the engine.
