Fog lights/ high & low beam for 2006?
I saw the post for keeping the fog lights on while the high beams are on but I have a 2006 QC and the fuse box is different. Anyone know how to do it on a 06? Pictures would be appreciated.
I to would like to see this reply, I have a 06 and have not looked in the relay box yet. I would think just find the same two relays, the must be labeled and jumper out the same way. I will look at it this weekend.
The 05's and the 06's are completly different electrical configs. The 06's it is controlled by a computer, in the 05's it is a relay. I looked when I saw the pictures and I notinced that the 06's fuse box looks nothing like the 05's. Can the option be turned on by the starscan tool at the dealer? If it can be turned on by the bullydog then shouldnt the starscan be able to.
I posted in the other thread trying to find out the answer. Someone must know something. Please post up if you have any ideas.
Trending Topics
the star scanner will change this and many other options. you will just have to ask the dealer to do them for you. the other option is to find someone with a bullydog downloader for an 06' model and it doesn't matter if your truck is diesel or not. it will work. the only thing I wish I could change but can't is the idle up feature on the diesel that you can't have on the hemi
F.Y.I.
The Star Scanner cannot program the fogs to stay on with high beams, there is a reason they go off....it's too bright to oncoming traffic, it would be a serious safety issue to blind other drivers.
