subs
Old Oct 28, 2006 | 06:09 PM
powerjunkie's Avatar
powerjunkie
Default subs
whats the difference between a 2 ohm and a 4 ohm sub. is the a sound difference. anything you would miss from the other. 2 ohms seems to be the cheaper way to go since the amps are cheaper since you dont have to get such a big one. thanks
Old Oct 28, 2006 | 06:51 PM
weswing04's Avatar
weswing04
Default RE: subs
They won't sound different from each other. They are just for different wiring options, depending on what your amp is rated for.
Old Oct 29, 2006 | 12:46 AM
powerjunkie
Default RE: subs
thanks that helps alot and probly will save some money too. i have another question though. if the amp is for 14v would i need a new head unit? thanks again
Old Oct 29, 2006 | 12:50 AM
weswing04's Avatar
weswing04
Default RE: subs
your head unit doesn't supply a lot of power to the amp. you can wire an amp off the factory head unit... the battery does the rest.
Old Oct 29, 2006 | 01:29 AM
powerjunkie
Default RE: subs
lol thanks again.
Old Oct 29, 2006 | 01:45 PM
djeazie's Avatar
djeazie
Default RE: subs
a 2 ohm sub operates more efficiently vs. a 4 ohm sub but a 4 ohm stable amp is easier to find and cheaper than a two ohm stable amp. There really is a difference my kicker amp wired in a 2 ohm mode is alot louder than running stereo 2 channel
Old Oct 29, 2006 | 04:20 PM
weswing04's Avatar
weswing04
Default RE: subs
ORIGINAL: djeazie
Not true. it was louder because the amp makes more power at two ohms. the different speaker versions are for wiring options, so you can get the correct load for whatever amp you have.
ie. two 4 ohm speakers will give you either a 2 of 8 ohm load, two 2 ohm speakers will give either a 1 or 4 ohm load.
Old Oct 29, 2006 | 05:43 PM
powerjunkie
Default RE: subs
how is a 2 ohm amp harder to find? all the amps ive been looking at are 2 or 4. and are cheaper to go 2 cause it takes a smaller amp.
Old Oct 29, 2006 | 07:50 PM
weswing04's Avatar
weswing04
Default RE: subs
I've never had a problem finding a 2ohm amp... and yes, a sub amp rated for 2ohms is a good way to go. how many of what kind of subs are you looking at?
