QUESTION ABOUT HEAT
Old Dec 7, 2006 | 01:07 AM
06ram's Avatar
06ram
Default QUESTION ABOUT HEAT
hey guys i havent been on here in a while i was busy starting my business, but anyway when i start my truck in the morning (06 ram qc hemi) it takes FOREVER for it to warm up...my 02 ford E-250 work van is much quicker to warm up....im not even talking REALLY cold out it could be 40-45 degrees....AM I THE ONLY ONE WITH THIS PROBLEM??....should i bring it to the dealership?[:@]
Old Dec 7, 2006 | 01:09 AM
cjpjjones's Avatar
cjpjjones
Default RE: QUESTION ABOUT HEAT
I have an 06 Ram QC Hemi and it warms up in about 5 min., which is pretty quick I would think.
Old Dec 7, 2006 | 01:12 AM
cr80renob's Avatar
cr80renob
My '05 1500 Reg. Cab takes forever aswell. Right when I pull into the parking lot (10-15 minute drive) the truck is finally warm. The way I got around this is remote start. Start my truck 10 minutes before I leave, and waaa laaa, it's warm!
Old Dec 7, 2006 | 01:17 AM
06ram's Avatar
06ram
yeah 10 minutes is about right...the remote start would be good, BUT i really dont want the truck idling at 7 am cause of the exhaust
Old Dec 7, 2006 | 11:49 AM
stump_breaker's Avatar
stump_breaker
Slip in a piece of cardboard about 5/8 to 3/4 the size of the radiator. It will warm up quickly. I have this on my Jeep and Honda and don't remove them. It will not cause overheating unless the outside temps start getting on up there.
You see Diesels doing this all the time.
Old Dec 7, 2006 | 12:08 PM
truckin151's Avatar
truckin151
Never heard of that method before but then again it doesn't get to cold in Arizona.
Now do you mean the truck its self doesnt warm up that fast or the heater isn't warming up very fast? With my 05' Reg. Cab 1500 it takes about 3-5 min for the truck to warm up in the morning, and about 5min or so for the heater to warm up. its in the low 40's - high 30's in the morning right now so its not too cold out.
Old Dec 7, 2006 | 04:32 PM
stump_breaker
All it does is reduce the air flow across the radiator to allow the engine to heat up faster. Vehicles with electric fans are not as prone to long warm ups but ones with clutch fans benefit greatly. With that being said, the Honda warms up quick but once you start moving, cools off quickly. The cardboard prevents this.
Old Dec 7, 2006 | 06:36 PM
06ram's Avatar
06ram
no the actual temp of the truck takes forever causing the heat to take forever....i'm really not happy about this
Old Dec 7, 2006 | 06:51 PM
DangDave's Avatar
DangDave
I was surprised at how fast I get heat on my new 06 Ram ST 3.7 6 speed
In about 5 blocks of stop and go driving it starts to put out warm air.
I usually go fast food for lunch and by the time I get through the drive though its warm
as far as heat coming from vents. The engine temp gage doesn't move in that time.
with my old 2000 Dak 3.9 it stayed cold the whole trip.
( back and forth to work )
Old Dec 7, 2006 | 11:19 PM
cr80renob's Avatar
cr80renob
Doesn't get cold in Arizona?!?! Up here in Carefree it'll get well below freezing. So having the heat take along time is Ridiculous.
