Just joined the warped rotors club at 22,500 miles
Old Feb 1, 2007 | 11:58 AM
eltupac's Avatar
eltupac
Default Just joined the warped rotors club at 22,500 miles
What can I say? I dont know if I should feel priviledged or be mad as hell. I have about 6000 miles with the OEM 20's and my rotors are warped. I can feel it when I brake. Before with the stock 17's nothing. I think it has to do with the bigger wheels and the little disks. I guess thats the price for looks.
Old Feb 1, 2007 | 01:35 PM
dillyw's Avatar
dillyw
Default RE: Just joined the warped rotors club at 22,500 miles
mine does that too but im going to wait till my breaks are low before changing them but mine is at 96k and its 03
Old Feb 1, 2007 | 05:07 PM
hetkind's Avatar
hetkind
they all do that, rotors are cheap...and easy to change.
Old Feb 1, 2007 | 06:15 PM
eltupac's Avatar
eltupac
So you think that even with the 17's, it would have warped.
Old Feb 1, 2007 | 06:38 PM
Limedust's Avatar
Limedust
There are two common reasons that rotors warp.
1) Wheel lugs get overtightened or tightened unevenly.
2) Rotors are cooled off too quickly after being hot. Good example is running through a puddle on a nice hot day after some braking.
I don't think switching from 17's to 20's is the problem. Now, if the 20's overtightened or unevenly tightened when they were put on...
Old Feb 1, 2007 | 07:19 PM
damquick1's Avatar
damquick1
and another common cause......riding the brakes...believe it or not it'll do it, too much heat on the surface where it dissapates quicker than inside the rotor disc and when they finally cool they are warped.
Old Feb 2, 2007 | 11:53 AM
eltupac's Avatar
eltupac
Damn shop. They put them on with the damn air gun. I'll bet that did it.
Old Feb 2, 2007 | 01:32 PM
Horseapples's Avatar
Horseapples
an impact wrench is fine for installing wheels as long as the tech used a torque stick. Did you watch them install the wheels? A torque stick looks like an extension but they are colour coded to designate the torque spec. I am not 100% sure,but I think he should have used a white torque stick
Old Feb 2, 2007 | 07:25 PM
JRH_PowerWagon_06's Avatar
JRH_PowerWagon_06
1) No air tools.
2) Use a torque wrench.
3) 115ft-lbs MAX..
Old Feb 3, 2007 | 03:08 AM
reiderr's Avatar
reiderr
I use an air wrench with a torque stick all the time. I used to follow it up a hand torque wrench just to make sure they were tightened evenly and to the correct torque--I use a 100 lbs torque stick since the DC specs 95 ft/lbs for 1500s. After a while I gave up on the hand wrench because the air gun with the torque stick was perfect every time.
