head gasket?
Old Feb 5, 2007 | 06:46 PM
duckhunter623's Avatar
duckhunter623
Default head gasket?
I have a 1500 4.7 liter there is white smoke coming out of my tail pipe only until the truck heats up, it is not overheating ,there is no milkshake in the oil.I have no idea what else it could be. any other ideas would be great THX.
Old Feb 5, 2007 | 06:49 PM
BgBluRam's Avatar
BgBluRam
Default RE: head gasket?
Is it cold where you are located... Meaning, are you sure it's smoke and not just steam?
Old Feb 5, 2007 | 06:51 PM
duckhunter623
no i'm in arizona and it was cold 30 or so when it frist started but it's still smoke's when it 70 out
Old Feb 5, 2007 | 06:52 PM
BgBluRam's Avatar
BgBluRam
hmm, What color is the smoke? White? Blue? Black?
Old Feb 5, 2007 | 06:53 PM
duckhunter623
White
Old Feb 5, 2007 | 06:56 PM
BgBluRam's Avatar
BgBluRam
White would mean that it is burning water.. You are not losing any water? and the water isn't milky? That just doesn't add up. I would take it to a reputable shop or the dealer and have them perform a pressure test on the cooling system to make sure there isn't a warped head, or blown gasket, as I can't think of any other way for white smoke to be produced..
Old Feb 5, 2007 | 06:58 PM
duckhunter623
It has just over 70,000 miles on it I did have the water pump go out about three week's before this happend I replaced it along with the raditor , fan, and fanclutch assy. But had no problems with it smoking until 3 days ago
Old Feb 5, 2007 | 07:03 PM
duckhunter623
Well i preformed a coolant pressure check and pulled plugs looking for any water on the plugs they where all good. It's in a shop as of this moring I am just looking for another answer other than the dam head's (something a little less expensive)
Old Feb 5, 2007 | 07:05 PM
duckhunter623
THX for your time Have a good one.
Old Dec 19, 2007 | 09:33 AM
mike0721's Avatar
mike0721
Could you tell me how this ended up for you? I am having the same issue. Also, did it make your truck idle rough? Thanks
