Power Wagon Problems-what Lockers?
My 2006 Power Wagon is in round two at the dealer for the same problem. The service 4x4 light comes on and the rear locker light flashes.
1st trip they replaced a torched bearing in the rear end and said that it was the metal shavings that caused the problem. The mechanic wanted to replace all the bearing but Dodge would not authorize so they only replaced the one bearing. One week later both front and rear lockers failed tolock inand the dealer has no idea why? My PW has been in the shop 4 out of the last 8 weeks.
Anyone else have similar problems? I have read several threads on the topic and it would seem that others have had issues getting the lockers to work. Runing in circles, cutting tracts in the sand and even plowing into dirt banks will not cause the lockers to work.
If anyone found a dealer who has identified and fixed the problem, any info would be of great help
I am just about ready to ask for a new truck but not sure of the lemon law. I am investigating now.
RE: Power Wagon Problems-what Lockers?
I have had nothing but problems with my lockers had them 'Fixed" 3 times now no matter what trick I try either advice from this fourm or the manual they dont work if I drive around in slow circles forward and back for 45 minutes sometimes and I say sometimes the rear will lock but its a tank of gas to get that to happen. Its a pain in the but t for me as the dealer is far away and never seems to have a loaner truck so on my 10k check up I will see what they say. Ill keep the fourm posted and best of luck as I know the bummer feeling of having a new machine and things come broken or do not work. Best Vibe Jimmy
Yes, I would agree they should lock without much problem. Have you looked at the electrical connections at the diffs, check the plugs and make sure contacts are being made and not dirty. Another thought may be to ckeck fuses and or relays for the system.
Good luck Jimmy1, M14 that is how my wagon use to work.
Well, I guess my next question is how many PW owners out there have lockers that work? If Iget a lawyer and the the dealer is forced to getting me a new PW, the last thing I want is the same thing. I will just take my $ and fix up my 1976 landcruiser. Although I need apick up for hauling my gear.
When I first got my PW the lockers worked well. My PW is primarily a hunting rig. Iuse the lockers, although most terrain I could get by without. It just makes for less stress and smoother ride when I can creep with lockers rather than run with standard 4x4 only. Here in Ariziona, slow, steep and crawl is the norm.
So if there are any 05' or 06 PW owners that have lockers that work/do not work Please post!
Many Thanks!
Many Thanks!
Trending Topics
Arrg, I figured there would be more problems with the Dodge than a Toyota[:@]. Jimmy, the connections on the diffs should be pretty obvious when you crawl under. I have only been under my truck once but I was not looking at the Diff. There should be a good size wire sticking out out of each pumpkin.
You would think it would be easy for Dodge to diagnose a problem, as the lockers lock based upon a bias observed between each wheel on the axel. If the electrical signal gets to the diff they should lock, so the components to check are power at the diff connection, switch in the cab, etc.
ORIGINAL: StarrFlight
M14
That is how my PW use to work. They have replaced the harness and a manual override will make the actuator work. The dealer has been on the phone with the factory and they guess it is a "computer glitch".
M14
