Last edit by: IB Advertising
Browse all: Engine Guides
- Dodge Ram 2009-Present: How to Change Oil
Step by step instructions for the do-it-yourself repairs.
Oil, change, types
"change oil" message shows on my EVIC for the 3rd time, and now it is only 2500 miles from my last oil change. i used mobil 1 5-20 extended performance (15,000 miles) and mobil 1 extended performance filter. I checked oil viscosity and it still looks clean. is this normal for new hemi engine?
Its not monitoring the oil.Its monitoring idle time.rpm range and a small host of other items.Reset it and drive it.The MAX oil change interval is 6k and 6 months and the oil you used will certainly go that distance if not much further.www.bobistheoilguy.com lots of OCD guys and info on oils and oil life monitoring.
My oil change due message appeared the other day.It was 5600 miles on the oil and filter. Changed it a few hundred miles later (just about dead on 6k)using Amsoil XL 5w20 and a Wix filter.Mainly rural driving,some interstate and some in the heart of Atlanta stop and go.I was curious to how many miles before it came on.Some of you all must be doing lots of short trips or stop and go driving to get it at the 2500 mile mark.
Same oil and filter etc. I read where some Chrysler products the OIL CHANGE message was coming on at 2500 mile intervals and they was a RRT/TSB re-flash for them.The TRUCKS were NOT involved in this BUT someone posted they bet if your computer needed updating it would take care of the 2500 mile oil change message.Either way STAR is more then likely aware and if you take your truck in for such the tech can contact STAR(engineering) for advice.
