Bakflip HD - not so HD
Old Oct 30, 2010 | 09:30 PM
  #171
oldjeep's Avatar
oldjeep
Where does yours leak? The only place I ever get water in mine is through the sides of the tailgate, and it has to be a pretty good storm for that to happen.
Old Oct 31, 2010 | 08:53 AM
  #172
rolltidehemi's Avatar
rolltidehemi
Mine leaks along the tailgate which expected, but it leaks around the hinged seals, it seems to come in from the outside edge and run along the bottom edge where it has the rubber hinge and drips some hinges more than others.
Old Oct 31, 2010 | 08:56 AM
  #173
rolltidehemi
Originally Posted by jmaimin
You're most welcome. I'm glad we were able to help you out.
Let me know what you think of your cover when it gets to you.
All the best,
Julian
Julian,
Could you see the above post and reply, my cover is only 10 months old, has had the leaks since new, also the rivets that hold the retaining clips at the front of the cover are rusting, and one of the support bars has had the rivet come undone on the inside rail, any help would be appreciated, been busy haven't had time to deal until seen the thread again.
Thanks,
Erik
Old Oct 31, 2010 | 09:59 AM
  #174
Fraenkyboy's Avatar
Fraenkyboy
Leaks, leaks, leaks...That is not Ok. Customers pay a lot of money and receive a bottle of water ;-). And Julian say 100% no water!!!!! All bad video on youtube with bakflip leaks are closed! Please why? Any problems? The problem is the bakflip self, the idea is very good, but the bakflip photos online says whats going on. This here are the problem customers! The good customers comes from sunshine state, pays the money, makes no trouble, and goes not online...Please bakflip customers let the windows open that is the same thing...
Never again bakflip ;-(
Fraenky
Old Oct 31, 2010 | 10:24 AM
  #175
oldjeep's Avatar
oldjeep
Fraenky
Once again - where is yours leaking from? Could be that you have a bad one, or it could be that it is installed wrong. Couple people who had leaks fixed it by installing a seal on the front rail of the bed - the 2nd bakflip I got came with that seal. Others have had issues because the rails were not installed square and the seal on the sides of the rails were not sealing.
I started this thread about a specific issue, which was resolved. Kinda wish that people would create their own problem threads rather than hopping on to this one - but I can't close it or lock it.
This video cleary shows a problem - looks like the seals that hold the panel into the hinge failed, is that what you are seeing?
http://www.youtube.com/watch?v=d4KY4ua9rPw
Old Nov 1, 2010 | 07:35 AM
  #176
jmaimin's Avatar
jmaimin
Former Vendor
Default BakFlip video
This video was taken a long time ago to demonstrate a problem that a customer had with AN OLD PLASTIC BakFlip cover that is no longer even being produced. The old Plastic covers had lots of issues, including expansion and contraction which caused the rivets to loosen over time, resulting in potential leaks like the one being demonstrated.
In all fairness, all BakFlip covers are now made with Aluminum and have been for the past few couple of years. The hinges on new BakFlip's are not even close to the hinge system on this old cover you're seeing either.
Nowadays, if there ever is a leak (which can occur with any cover), it is rarely (if ever) a problem with the cover and almost all the time, an issue with the install. If it ever is an issue with the cover, I will be the first to replace it for anyone!
The great thing about the net is that it allows truths to be shared. The bad thing is that truths can be taken out of context and do not always accurately depict reality. Audi was once a brand that had its fair share of problems. Today, it's one of the best and most reliable vehicles you can buy. Imagine thinking of buying one and watching a video of an old Audi that had breaking or transmission issues. The video, while probably factual for the time, would in all honesty have little baring on today's models being sold. I think it's a good way to some up BakFlip and the way it is largely regarded in todays industry.
I can certainly understand where anyone would be hesitant to buy a cover that could potentially leak, however if it's any consolation, I can personally assure you that the range of BakFlip covers are terrific and the vast majority of BakFlip owners will attest to this as fact!
All the best,
Julian Maimin - COO
BAK Industries
Old Nov 2, 2010 | 12:54 AM
  #177
JRI's Avatar
JRI
I purchased a BackFlip F-1 cover this year. It leaked. I re-installed it using spacers and now it does NOT leak.
I am very happy with this cover and admit that the leak problem was my fault due to improper install.
I have no problem recommending this cover.
Old Nov 2, 2010 | 01:17 PM
  #178
rolltidehemi
My F1 did not come with spacers, I need to contact them I guess.
Old Dec 2, 2010 | 09:06 AM
  #179
pfd161's Avatar
pfd161
I think it's great the COO of a company will come here and defend his product and tell us he stands by it. I will def. be considering this cover form my new ram.
D.
Old Dec 2, 2010 | 09:32 AM
  #180
'05Train's Avatar
'05Train
I've had a Bakflip F1 on since early August. I get water in the bed when it rains, though I believe the vast majority of that is coming through all the holes in the bed. The cover leaks, but not appreciably so.
My biggest issue with the cover is the struts that hold it open. The clip on one side that holds the strut to the bedrail broke last month. A minor thing, I guess, but pretty disappointing given what the cover cost.
I think the F1 is still the best option out there for someone like me who uses the bed to haul a lot, but it's far from perfect.
