MDS TCC Droan Shutter issues: response from Dodge
Old Nov 23, 2010 | 09:10 PM
  #21
Cdubba's Avatar
Cdubba
I have the same issue but was wondering if it had to do with my aftermarkt muffler?? i have a single pipe hemi and i replaced my muffler with a flowmaster single in singleout and left my stock resignators with tail pipe?? anyone think ithas any coorilation with each other.. and another thing what if i just put a single in double out muffler on it and dumpedthe exhaust (turn down) getting ridof my rear resignator and tail pipe?
Old Nov 24, 2010 | 10:42 AM
  #22
Ross -in-Georgia's Avatar
Ross -in-Georgia
I have a 2010 TRX4 QC.... I also have the same issue. I noticed this a lot more after I swapped out my exhaust... Dual out behind the tires magnaflow muffler. I will be taking my truck back to the dealer for the K17 recall... Please let me know any info you find out about this.
Ross
Old Nov 24, 2010 | 11:57 AM
  #23
Wicked Mayhem's Avatar
Wicked Mayhem
i have this problem too.. but i just run the truck in tow/haul mode so it doesnt kick into mds.. sound is so annoying with my magnaflow and when the mds kicks in anyways.
Old Nov 25, 2010 | 01:03 AM
  #24
HEMI5150's Avatar
HEMI5150
So the people that are complaining about the MDS rattle,
why dont you guys just drop the shifter out of overdrive (???)
If you`re in 5th gear instead of overdrive, the MDS deactivates
Old Nov 25, 2010 | 09:30 AM
  #25
BigBlueEdge's Avatar
BigBlueEdge
I've had the same issue from day one on my Sport. It definitely seems like it is related to MDS, so that part doesn't surprise me. But I've had MDS in a 5.7L in a Grand Cherokee that was perfectly smooth, so either it is something with newer Hemis or the torque converter interaction is a big part of things. Sounds to me like they just need to do a little more tuning of some RPMs and shift points to find a way to avoid it. Anyway, I'm subscribing in case some solution turns up.
Rob
Old Nov 25, 2010 | 09:45 AM
  #26
trashman139's Avatar
trashman139
mine is bad. since i switched exhaust i know when MDS kicks in droan is real bad and alot of vibrations it almost feels like it needs a tune up.
Old Nov 25, 2010 | 09:54 AM
  #27
oldjeep's Avatar
oldjeep
The TC shudder seems like a real issue, rarely happens on mine but I know the feeling yu guys are describing.
However, it sounds like about half of the "problems" that people are reporting are caused by swapping out the muffler they designed for the motor with an aftermarket noise maker. There was even a recall a while back to swap quieter mufflers on some models which were having drone issues.
Old Nov 25, 2010 | 10:00 AM
  #28
72combo's Avatar
72combo
Mine is still undetectable except for the fuel saver light. Getting wonderfull mileage just got one problem the drivers side mirror quit defrosting not sure what it is but gotta get it in beforr the snow hits.
Old Nov 25, 2010 | 10:38 AM
  #29
mike2810's Avatar
mike2810
Mine Hemi is seemless. I cannot tell when mds is active or not except when I look at the saver light. My truck is stock.
For those of you having issues, did you have the problem prior to swapping out exhaust systems?
Old Nov 25, 2010 | 11:24 AM
  #30
hounddogg's Avatar
hounddogg
Mine is smooth.All that changes is exhaust tone with the magnaflow and it dosen't bother me at all.
