Ground Force 2/3" drop kit installed -pics
Old Dec 9, 2010 | 08:51 AM
Twist's Avatar
Twist
Default Ground Force 2/3" drop kit installed -pics
It was time to change out the tires on my RAM so I installed Parada Spec-X 305/50-20 tires which are a little lower and a little wider then the Goodyears that came on the truck. Once they were on the truck I did not like the look with all the space around the front and rear tires. I decided to install the Ground Force 9984 2 / 3" drop kit to level the truck and hopefully make it look better with the new tires. The kit is not too bad to install, but I did run into a few tough spots. The front struts were a real PITA to get the main strut nut off, and the rear shocks top mount is not easy to work with. You do have to pull everything apart up front.
The rear air bag setup had to be modified, but still works for hauling. The ride is very good with a minor change towards a sports feel.
A few Pics -
Front End apart
Rear apart
Front Struts
Rear Springs
Truck Finished
Old Dec 9, 2010 | 07:02 PM
09 Ram TRX 4 Lover's Avatar
09 Ram TRX 4 Lover
Hey that looks really good.
Old Dec 9, 2010 | 10:17 PM
10RAMSPORT's Avatar
10RAMSPORT
Love the wider tires!
Old Dec 9, 2010 | 11:12 PM
Wil09RamSport's Avatar
Wil09RamSport
love the new look, looking forward to do the same to my truck as well....
Old Dec 10, 2010 | 07:10 AM
Twist's Avatar
Twist
Thanks, The alignment guy said it looks like a 2wd now - lol, but still seemed to like it. My wife is 4' 11" and now its much easier for her to get into the truck. It still has a slight rake to it, but not as much as it had before.
Old Dec 25, 2010 | 02:14 AM
moosefire66's Avatar
moosefire66
How is your towing now with the lowering kit? Any difference in how much lbs you can tow?
Old Dec 26, 2010 | 01:08 PM
Twist's Avatar
Twist
I have not had a chance to tow with it yet so I can't really say. I discussed towing and loading the truck with Ground Force and they said when they tested a truck with the kit it was fine at 1100 pounds. I also have the 1000 pound air bags on the truck so I should be okay with both loads and the trailer.
Old Dec 27, 2010 | 01:17 AM
rdculus's Avatar
rdculus
Looks great! I love the lower stance
Old Dec 27, 2010 | 05:26 PM
moosefire66
Does lowering a 4wd truck affect the 4wd capabilities? I.E. binding, affect the turning radius, etc??
Old Dec 28, 2010 | 07:27 AM
Twist's Avatar
Twist
[quote=moosefire66;2362019]Does lowering a 4wd truck affect the 4wd capabilities? I.E. binding, affect the turning radius, etc??[/quote
My 4wd seems to work just the same as it always did. Actually, everything works just the same except for the ride. The truck does ride a little firmer but, when you take a turn it does not roll over as much. For me, this is a change I wanted to have.
