V6 electric fan installed on Hemi
Old Apr 9, 2012 | 02:57 PM
Cmerritt84's Avatar
Cmerritt84
Well the stock clutch fan is a constant draw on the motor. It engages by heat.
The stock ac fan is electric and comes on with the ac. The electric fan I put on is doing both jobs. More throttle response and better mpg. It's a performance and mpg mod
Old Apr 9, 2012 | 04:16 PM
roju6's Avatar
roju6
Yeah I get the clutch fan being a constant draw, I've seen drastic improvements in mileage when I put e fans on my F150 but those didn't have the a/c fan like the Dodge does.
The a/c must have a thermostat trigger as well though otherwise changing the trip points with a tuner wouldn't make any difference. If you didn't have to do any wiring and it was all plug and play then the stock a/c fan must kick in at a certian temp as well which is why I was wondering if it would be necessary to remove both fans and replace it with a different fan.
I read some other posts on another forum where guys were removing the clutch fan and leaving the stock a/c fan to do both jobs.
Old Apr 9, 2012 | 08:22 PM
InterpunX's Avatar
InterpunX
Why wouldn't dodge put an efan with the hemi in the first place, just like your setup. Also where did you get something like that.
Old Apr 9, 2012 | 08:48 PM
Cmerritt84's Avatar
Cmerritt84
I'd you want one email JJ
Jeremy@retroshop.us. Ask for hemi e fan. It's a TYC OEM style aftermarket unit. Functions just like OEM.
Read this thread. All about this and on 1st page has OEM mopar part number.
http://www.*********.com/forums/showthread.php?t=347305
And read this thread on it.
Cmerritt84's Avatar
Cmerritt84
The ****** are dodge talk. No spaces.
Old Apr 9, 2012 | 08:50 PM
Cmerritt84's Avatar
Cmerritt84
Plus the ac fan is only to cool the compressor. Not the entire engine. The electric unit I installed does both jobs.
Old Apr 10, 2012 | 10:26 AM
roju6's Avatar
roju6
Thanks Cmerritt84, after reading that post it seems like the factory plug has a lead for a temperature control but the factor a/c fan is only switched on with the a/c whereas this other fan will kick on based on a/c as well as temperature.
FYI for anyone asking Jeremy I just emailed him and he doesn't have that deal available on these fans anymore, amazon still has them though if you look up item number 622320.
Old Apr 14, 2012 | 04:45 AM
huntergreen's Avatar
huntergreen
great find, but can it work on my 11 as there are no programmers avilable for this model year?
Old Apr 14, 2012 | 04:47 AM
Cmerritt84's Avatar
Cmerritt84
Yup. Will work on -- will kick on at 222
Old Aug 25, 2018 | 03:56 PM
EricBing's Avatar
EricBing
Default Compatibility??
When I looked up that part number, says it won't fit my 11 5.7, is that because it's for a v-6??, I'd like to be sure it bolts b4 I order one for plug an play, I have a superchip 3845, wonder if I have flexibility to change trigger point, or do I need to bother with that...stock thermostat
