improving gas mileage 4G
Old Mar 12, 2013 | 12:52 PM
RamJay's Avatar
RamJay
Default help with mileage?
In the 2013 Ram literature they mention wheel to wheel step bars help some. Heard a tonneau cover will help as well.Dont know if either is true though.
Old Mar 12, 2013 | 11:21 PM
LU229's Avatar
LU229
It has been already proven that tonneau covers WONT get you any better mpg`s... neither will step bars
Old Mar 26, 2013 | 04:01 AM
Arachnyd's Avatar
Arachnyd
CAI will lower your fuel economy drastically.
The roar sounds SOOO good you start gunning it every chance you get. Dropped my fuel economy down to 12.5 MPG. Took it off and went back to stock and its back up to 14.5
I think it was my changed behavior that did it, and it had nothing to do with the actual parts.
Old Mar 27, 2013 | 02:04 AM
LU229's Avatar
LU229
AGREED...!!!!!!!
The stock OEM air box`s are tuned very well to these 4th gen trucks...!!!
Old Mar 30, 2013 | 09:54 PM
HammerZ71's Avatar
HammerZ71
You can squeeze out a tad better fuel economy with a CAI but not by itself. Think of it like the old "chain is only as strong as it's weakest link" adage. You'll benefit by the added surface area of a cone type filter BUT only if you port the throttle body to accept more airflow AND then you need to consider an intake manifold with runners that can make use of the extra air coming in. NOW you need to consider the natural backflow of exhaust into the cylinders at the exhaust manifold so you'd need headers to properly scavenge this air. Of course now you have to think about the cats, any restrictions in the exhaust such as pinched "Y" pipes and possibly the muffler.
My point is that it is possible to get a tad more MPG (and about 30 or so RWHP) by completely redoing the intake and exhaust BUT you'd better plan on owning your truck for about 30 years or so to make up the cost of the mods in fuel savings.
The only real modification I've seen that doesn't take a crazy long time to make up it's cost in fuel savings is going to an e-fan. They aren't terribly expensive and are quite easy to install without having to pay for labor. Of course, the benefits of an electric fan are seen most in town where you start/stop and accelerate from a stop or slow speeds often. An e-fan losses it's physical advantage over a clutch fan on the open road where engine RPMs minimize the parasitic loss a clutch fan causes at low RPM.
Old Jun 17, 2014 | 09:15 PM
Rammdiculous's Avatar
Rammdiculous
So i just bought a 2010 Dodge Ram 1500 Reg Cab, 2WD, 4.7L, and i am looking into modding the truck, id like to try and pump out atleast 50 RWHP.
im still learning about the truck so i would highly appreciate any and every input possible!!
ive done some reading, and came to find out that theres not too man mods for the 4.7L
Also a questions that i had was if i could install a LSD?????
Old Jun 30, 2014 | 11:51 AM
NV290's Avatar
NV290
Start a new thread asking this question. You will not get the answers you need about adding HP to a new truck in a thread that is based on how to improve MPG's.
Old Jun 30, 2014 | 06:38 PM
bluebeast1562's Avatar
bluebeast1562
I truly believe that if ethanol is taken out of our fuel then we will get better HP and MPG's. Use corn to feed the people not our vehicles.
