anyone install an electronic brake controller?
Old May 16, 2009 | 12:43 PM
  #41
BubbaRadioNetwork's Avatar
BubbaRadioNetwork
Originally Posted by Twist
I installed my Prodigy yesterday in the little cubby above the brake release like an earlier poster did. It was real easy to do, and it looks good. I had to trim the top off the cubby but that is no big deal. Seems like the ideal place to put it IMO.
Can you post a pic? The previous pic in this thread was of a Primus and the Prodigy is made different. Thanks.
Old May 16, 2009 | 07:37 PM
  #42
72combo's Avatar
72combo
Originally Posted by qicvick
Thanks for the update, wonder if velcro would work, I put some of that on a cabinet door that had a broke latch on my travel trailer and when I shut the door u could still see part of the tape, I went the relocate the tape and it was peeling the lamintion off the door !
velcro should work as long as it is industrial type not the kind your wife uses making curtains. Be sure to clean the plastic with alcohol or methyl hydrate then the velcro should stick, let it sit on each piece before you put them to geter. Rub and put pressure on it to make the pressure sensitive tape work. Good Luck. Works for me all the time. hung door panels like that once.
Old May 19, 2009 | 10:06 AM
  #43
Twist's Avatar
Twist
Sorry it took me a few days to post a pic, but here it is -
Old May 19, 2009 | 03:43 PM
  #44
BubbaRadioNetwork
Thanks for the update.
Old May 19, 2009 | 10:25 PM
  #45
Brummo's Avatar
Brummo
I guess I didn't try hard enough, but I didn't think my prodige would fit very well, so I mounted it under the ignition by my right knee.
Old May 19, 2009 | 10:47 PM
  #46
BubbaRadioNetwork
He cut out the inside of the cubby hole to get it to fit.
Old May 19, 2009 | 11:31 PM
  #47
Brummo's Avatar
Brummo
Ahh, got it. Thanks
Old May 27, 2009 | 03:06 PM
  #48
Eric Brown's Avatar
Eric Brown
Default Brake Control Wiring Harness
Purchases a Valley Odyssey 2 controller...It came with a harness #30506. They say it should just plug into the harness under the dash close to the emergency brake...not so.
The dealer has removed the harness as of 2007....so you have to purchase a harness from them to plug in the controller...simple to do just more money.
The dealer said people didn't use them so they have been removed for re-sale...what a scam.
Old May 27, 2009 | 03:19 PM
  #49
Sobomaster's Avatar
Sobomaster
My '07 had a harness and my '09 has a harness that most brake controllers will work with.
Old May 27, 2009 | 03:36 PM
  #50
72combo's Avatar
72combo
Maybe they meant they were in all trucks, they only put them in vehicles with trailer hitches now possibly. I will have to have a look and see when the wife gets home, she always takes the truck now, man I get stuck with the 72 chev all the time...so okay, the tires on the 72 are much cheaper 15" 275-60 15 nice and wide BFG's I finally got my spacers to fix the rubbing now I have to get out there and get someone to help me put them on.
