HID Lights
Old Mar 14, 2009 | 11:17 PM
  #41
Indianadodge's Avatar
Indianadodge
why not put hid in the high beams?
Old Mar 15, 2009 | 12:42 AM
  #42
Thatmarkguy's Avatar
Thatmarkguy
Because HIDs require a start-up time. If you never have to flash someone, then I guess you'd be okay.
Old Mar 20, 2009 | 06:10 AM
  #43
HEMIBOY04's Avatar
HEMIBOY04
Originally Posted by adamtrahan
I have a 2009 Dodge Ram 1500 and I have the same problem. I installed a 6000K kit and it is fine while the truck is off but when it is running they flicker. The company sent me some resistors and I installed them. It didnt change a thing. They said now they are going to send me some "cancellers" and that should fix it. Any other suggestions if that doesnt work? Here are some pics.
your lights look REALLY good!!! is there anyway you can take a head on night pic and the cut off lines on a garage door or wall??? i know you mentioned to someone else that you have to ask the company to send the cancelers with the order but how much extra for those???
Old Mar 22, 2009 | 01:31 PM
  #44
Thatmarkguy
I paid an extra $30 for my cancelers. You can get the same cut off lines with the halogens, it just won't be as bright.
Old Mar 22, 2009 | 03:36 PM
  #45
navyr6's Avatar
navyr6
Originally Posted by Thatmarkguy
Here's some pics:
The picture on the left shows the color difference between the HID and the Silverstar Ultra.
The right one shows both the low and high beams on at the same time.
how did you get your low beams and high beams on at the same time? i had that on my 02 silverado and would really like to have it on my new ram.
Old Mar 22, 2009 | 03:49 PM
  #46
Indianadodge
I'm pretty sure if your truck has the quad headlights the lows stay on when you turn the highs on. That is the case with my 09 with the quad headights.
Old Mar 22, 2009 | 10:18 PM
  #47
adamtrahan's Avatar
adamtrahan
Thanks. The cancellers were free. I just told him about the problem I was having and he sent them out...no charge. I am loving the lights now that the problem is fixed. I'd do it if I were you.
Old Mar 24, 2009 | 01:36 PM
  #48
Dodge Ram Laramie's Avatar
Dodge Ram Laramie
Anyone find out more info if installing these voids coverage on maxlife warranty? Which Kelvin is the brightest? 5000K or the yellow 3000K?
Old Mar 24, 2009 | 04:38 PM
  #49
Thatmarkguy
The Kelvin rating is the temperature (color) of the light. 3000K would be yellow and annoying, 4300K to 5000K would be in the white range, where 6000K to 8000K would be blue and on up to purple 10000K + and useless.
Old Mar 25, 2009 | 09:23 AM
  #50
Dodge Ram Laramie
I read somewhere that the higher the Kelvin the less brightness you get. Is this true?
