View Poll Results: Was This Post Helpful?
Yes - Very Helpful
8
80.00%
Maybe - Somewhat Helpful
1
10.00%
No - I Already Knew this Infomation
1
10.00%
Voters: 10. You may not vote on this poll
Locking Tailgate Installation - Walkthru
#71
locking tailgate chrysler.
I'm in Ontario and have an 09 Ram that did not come with the locking tailgate.I contacted Chrysler Canada and complained about this and they contacted my dealer. My dealer ordered the parts for me and installed it for me today all at their own expense. Got to love that.
#72
#73
Mine came with a lock --
I'm about to replace the whole assembly with the kit that includes a handle with camera and lock.
Anyone interested in the one that's coming out -- Mopar remote tailgate lock installed so no wear on the lock?
Make me a reasonable offer plus shipping for the whole thing.
Note -- I have turned a key in this, so it is set for that key.
Also have the original sattelite radio which was replaced with REN unit to display the rear view camera feed.
#74
Well, its done.
Not sure about that whole lock cylinder. I am 99% sure MOPAR no longer includes the lock, you must order the handle with the hole and the lock seperate, another $67.00 (I was lucky to get for $42 as my buddy works parts). Total cost for everything for me was $140 out the door.
Used Locktight on the tailgate nut to ensure it doesnt vibrate loose. and soap on the rods to slip off for the old, and on for the new rod.
Great post BASSMAN (Hope thats right), great detail, honestly perfect..
RECAP-
I think the days of getting the handle with the lock are gone. Still is a hell of a lot cheaper than going the OEM route (NEW locking handle mechnasm was over $200) or the electronic part which is still a bit of change, and requires the lock componenets to be there already. But Dodge has suceeded the original parrt number with some new ending numbers, meaning they split the handle and lock up.
Hope this helps, and if someone can prove me wrong and finds that the handle part number does come with a lock, i would love to know (As long as its current information)
RECAP-
#76
#77
Installed Elec Tailgate lock on 2012 1500 Crew Cab
It went really well, until the wiring! I thought the connector cavity info in the instructions was not correct for the 2012, but it was not far off. It turns out the picture of the connector is from the bottom view, and damned if there are not tiny little numbers on the bottom indicating the cavity numbers. So the 2011 pin locations are the same as the 2012, but the wire colours were different than what has been said here before. Mine were tan and tan w/ blue stripe.
The kit wires were black and red.
Black goes to cavity 20 on connector "F" (grey plastic) Lock driver
Red goes to cavity 7 on Connector "E" (brown plastic) Unlock driver
I stripped (without cutting the wire), wrapped, soldered, and insulated with self-amalgamating rubber splicing tape and standard electrical tape. I hope it doesn't really need to be crimped too.
Glad to be done using that little key from the FOB. With the hard cover that can't be opened without opening the tailgate, this kit is the cat's ***.
#78
#79
I think the problem may be the format of the search text you used. Try just the number part. Sometimes Chrysler changes the alpha characters for each new 'version' of a part. I searched on "68044904" in Google 'Shopping' search and got various hits. Looks like they are up to AD now. You can also eliminate the dash and try "68044904AB".
You'll find some.
Rob
You'll find some.
Rob
#80
Thanks for the help, when I did the search as you described I got an alternate part number (68071073AA), so I will do that for the other 2 parts I need and hope to get a locking tailgate.
One last thing, "if" i want the power tailgate lock I DO have to to get all three parts mentioned in the first place, correct? I need the manual locking items to make the power locking stuff work, correct? From reading lots of post this is the way it seems to be, just want to make sure.
