MDS won't kick in at 60mph
Old Apr 13, 2009 | 09:36 PM
frofro666's Avatar
frofro666
Default MDS won't kick in at 60mph
Hi guys! Just picked up my new 09 quad cab 4x4 with the hemi in it. I noticed around town the "fuel saver" light goes on, but at any speeds above 50mph it won't go on. Is it because its so new? (20 miles on it)? I had the cruise set and there was no wind and on level ground. What gives? Normal?
Thanks in advance!
Old Apr 13, 2009 | 09:43 PM
CarGuyOhio's Avatar
CarGuyOhio
Well, that is not normal, if I am not mistaken 70 is the magic number where it will not engage.
I assume you are in drive and not manually shifting and your tow haul is off?
Old Apr 13, 2009 | 09:45 PM
frofro666's Avatar
frofro666
Yes in drive, not manually shifting, and tow haul is off. Maybe cuz its just breaking in?
Old Apr 13, 2009 | 10:05 PM
sarguy01's Avatar
sarguy01
The MDS may take a while to start working all of the time. There was a notice in my owners manual. Same thing if you disconnect the battery.
The PCM needs to "learn" your driving habits. I think.
Old Apr 13, 2009 | 10:21 PM
Inbred's Avatar
Inbred
Ditto.
And there is no magic number where it cuts out, it is all about load. Now in most circumstances, you won't have a light enough load at 70 for it to stay in fuel saver most of the time save for going down hill. I had MDS kicked in at almost 75 last week down hill. Maintaining at 70 it is in about 50% of the time. 67 it is about 80% when maintaining.
Old Apr 13, 2009 | 10:25 PM
capsfloyd's Avatar
capsfloyd
No mine will kick above 70-75..
Old Apr 13, 2009 | 10:35 PM
CarGuyOhio's Avatar
CarGuyOhio
That will be nice. I set the cruise at 75 in MI often. Will probably depend on wind direction.
Old Apr 13, 2009 | 11:22 PM
frofro666's Avatar
frofro666
I have only driven the truck once ( just picked it up today) so maybe it does need to learn. It does come on when i am decelerating from 60mph tho. It says I am getting about 16mpg on the hiway right now, but thats not bad considering it has to break in....I think.....hoping...
Old Apr 13, 2009 | 11:30 PM
capsfloyd's Avatar
capsfloyd
watch the water temp gauge , after 2000-3000 the temp will go down some?
Your milage will get better. The Hemi really scared me with thw mpg. I drive 40,000 plus a yr. I am getting better milage each week. 5049 miles now.
Old Apr 14, 2009 | 12:14 AM
frofro666's Avatar
frofro666
sounds good!
