Question on wheel alignment
First off sup everyone, got my first dodge truck few weeks back and loving it! I'm going to install a leveling kit on the ram this weekend which alters both the front and back but my question is when i should align it. I am going to use the stock wheel/tire setup for a while but maybe in the next month or 2 i will be getting some 18"s with 33"s so will it be the same alignment if i get it aligned right now with stock wheels or is the alignment going to again be off after the new wheels? I'm just trying to avoid getting it aligned twice, but i am thinking getting it aligned once after the lift kit no matter what wheels are on will be just fine. Thanks!
If you're just throwing a leveling kit on it, it more then likely won't alter the alignment. Even if it does, it won't be off that much and I think you will be fine for the couple months until you swap your wheels and tires. You're definitely gonna want to align after that. Might as well save the money and wait.
TRX comes with tow hooks. I would get the truck aligned, I leveled mine and had it aligned the next day. It drove fine, but the analysis of the alignment showed that is was out. It was 60 bucks. It doesn't matter that you are switching wheels/tires.
Trending Topics
Yeah like I said, it might be out a little bit, but if you're wantin to save money and you're gonna get it aligned 2 or 3 months later I think you'll be alright. Especially if you're not gonna keep the old tires. Odd wear will probably occur and maybe a little shimmy in the steering wheel at higher speeds, but that's about it. It's up to you and how bad you wanna save the 60 or 70 bucks to get it aligned. If it was me I would just have to see how it rides after the leveling kit and go from there. If there's extreme shake in the steering wheel then obviously I would get it aligned, but I don't think that's going to be the case.
New truck = however many thousands of dollars
Accident cuz steering issue in the rain from an poor aligned truck= however many thousands of dollars plus the insurance increase etc.
Alignment = peace of mind, and safety. Its only 60 bucks.
I get an alignment every year or tire rotation, you never know when parts can go. Remember the Durango recall for ball joints?
