Design Pet Peeves (everybody's got them)
Old May 19, 2009 | 05:23 PM
  #41
spoon's Avatar
spoon
The evic display is very difficulto to read/see in poor light conditions ie light shining into it. Dissappinting choice of reflective materials for the display cover. Ditto for Navigation display.
No place to put sunglasses...
Driver side bottom door pocket is inaccessible when driving...
Why no Actual MPG and MPG since start?
+/- gear shifter should have been forward/back instead of left/right
Rearseats should have option for backs to fold down.
Antenna should have been built into the windscreen or other place.
Old May 19, 2009 | 05:37 PM
  #42
jawsdc's Avatar
jawsdc
good call on the sunglasses spoon, that bothered me too. i eventually found a good place to keep maui jims flex frames. they fit nicely on top of the rear view mirror w/ the arms around the mirror mount.
Old May 19, 2009 | 05:39 PM
  #43
HemiRAMV8's Avatar
HemiRAMV8
For those that are upset about the console shifter moving left/right, I wholeheartedly disagree.
I've had a VW in the past where from Park, you pulled it back to D, moved off, then moved it left out of D into the Tiptronic mode and then nudged it forward or back to change up/down. So much of a PITA that I never bothered, and just drove it in D.
Contrast with Mercedes or RAM. Pull back to D, drive off. Nudge left/right to change.
I guess I do have one gripe. Nudge it left from D and it goes to 5. Effectively the same as where you were (except no MDS). Why not have it go to 4 on the first nudge left?
Old May 19, 2009 | 05:56 PM
  #44
oldjeep's Avatar
oldjeep
Only 2 things I've noticed is
No sunglass holder
Rear needs individual map lights - so one of the kids can read, whatever if they want.
Old May 19, 2009 | 07:38 PM
  #45
Thatmarkguy's Avatar
Thatmarkguy
That chrome trim around the shifter on the console. It seems in the afternoon the sun's always reflecting back at me, arghhh!!!
Old May 19, 2009 | 10:42 PM
  #46
Brummo's Avatar
Brummo
No sunglass holder
I have the console/floor shift and my sun glasses fit right under the climate control. Maybe I have a little more storage or places to put them with the console.
Old May 20, 2009 | 09:39 AM
  #47
Hop's Avatar
Hop
So far my only gripes so far are:
Chrome console trim blinding me, backup camera is hard to judge, no blind spot mirrors, no coin holder, steering wheel is too slippery (might be becuase I used leather cleaner on it), gas cap holder. I'm sure I'll find others and some of these may grow on me. I've only had the truck for 5 days.
--Hop
Old May 20, 2009 | 09:47 AM
  #48
oldjeep's Avatar
oldjeep
Could be. I've got the 6 seat configuration, so there is a pull down cup holder under the climate control panel. you can toss the glasses in one of the cup holders, but the last 5 cars I've had - had a sunglass holder in the roof console.
Old May 20, 2009 | 09:49 AM
  #49
oldjeep's Avatar
oldjeep
Originally Posted by Hop
gas cap holder.--Hop
There is a gas cap holder, just not the sort most people are used to. That little tab on the inside of the door does the job. (on my 09 SLT anyway)
Old May 20, 2009 | 10:16 AM
  #50
72combo's Avatar
72combo
Originally Posted by Thatmarkguy
Now that you mention it, the UConnect button should be on the steering wheel, not the radio.
I don't like the console shifter. You should have to move the shifter over to another gate to change forward gears. I've noticed that when I make a left turn and I have my hand on the shifter, as the truck turns I'll pull the shifter over and it'll hang in first - not a good design. On my wife's BMW you have to move the lever to the left and then toggle it forward or back to change forward gears.
Another thing that gripes me is the Tow/Haul button - when it's engaged the truck will only go to 4th gear even though 5 is displayed in the instrument panel. It should shift into 5th so when you're on a flat highway you don't have to worry about pushing in the button to get your MPG up when you're towing.
Not sure it is such a good idea to be using the shifter as a handle to hold yourself while driving. Technically you should have 2 hands on the wheel. I am paraplegic and have the console too and I have no balance from my **** down, and I don't have to hang on to the shifter when I drive. There are a ton of places to put your sunglasses when you have the center console.
