Adding front tow hooks to an '09 SLT ?
Old May 8, 2009 | 10:42 PM
DroopyDog's Avatar
DroopyDog
Easy as pie to put on. I didn't like the trim piece after I cut it out. Used a Dremel. I ordered the TRX trim piece which is pre molded and it works great. About $9. The hooks were $187 from the dealer.
Old May 11, 2009 | 09:41 AM
HG07JKRubi's Avatar
HG07JKRubi
Wow - that's a lot! I wonder if there are any aftermarket options for front tow hooks yet ???
Old May 13, 2009 | 02:43 PM
NCBigHorn's Avatar
NCBigHorn
rubi, look here. i have been meaning to get some for my big horn but haven't got around to it. some guys here on the forum gave me this link. they are only 109$ shipped i believe.
http://www.trademotion.com/partlocat...24&startrow=11
Old Dec 9, 2009 | 07:48 PM
B.Kaiser1's Avatar
B.Kaiser1
Originally Posted by bparent
Good call. I was so excited when I put them on I never noticed. I will change them right now. Thanks for the keen eye.
Brian
Mine had a locating pin on them and would only fit properly one way...Opening to the outside.
I could see if you weren't paying attention it would be easy to switch them and bend the bracket that the locating pin is installed in when you tighten the nuts.
You might want to check on that!
Old Dec 10, 2009 | 06:16 AM
jiffer's Avatar
jiffer
Has anyone actually added these to a sport model? I'd love to know for sure before I take the plunge.
Old Dec 10, 2009 | 12:36 PM
shadow11's Avatar
shadow11
The stock 4x4 sport rams don't come with tow hooks so they probably can't be added.
Old Dec 10, 2009 | 06:47 PM
bparent's Avatar
bparent
Mine also had the locating pin but were assembled wrong from the factory, thats why I thought they went on that way. I had to disassemble the hook from the mounting plate with the locating pin and swap it with the other hook. So if anybody gets these just make sure the hooks are assembled correctly. If not for this fourm I would still be running around with them on wrong.
