My Retrofit Camera
Old Jun 25, 2009 | 09:25 PM
hawk570's Avatar
hawk570
Originally Posted by Doc Fluty
questions..
1. i dont have the nav.. but i do have the touch screen hard drive version. so will this camera work with my unit?
2. how does it hook up? are there rca jacks in the back to run it too..
3... umm... anything else we should kww?
thanks.. and nice clean install bud
Contact NAV-TV, I'm pretty sure they have an all-gig for your radio. You can buy direct from them and they offer awesome customer service.
As for the hook up, you need the all-gig and the A/V cables sold ny NAV-TV. The A/V cable plugs into your radio harness giving you the RCA jack needed for the camera. Pretty easy install. The hardest, or should I say, most time consuming part was runnng the RCA and power cable underneath the truck.
Old Jun 25, 2009 | 09:29 PM
hawk570's Avatar
hawk570
Originally Posted by Chaosrawn
I didn't know it would do that! My wife wants to watch the movie with the kids (they have ceiling mount DVD with wireless headphones.)
The wife loves being able to watch movies while I drive. Another neat feature is that you can actually turn the camera on anytime you want without having to be in reverse. This is done by pressing the volume **** twice.
Old Jun 25, 2009 | 10:40 PM
Chaosrawn's Avatar
Chaosrawn
That's cool. Does this mean all I need is All-Gig to get the movies to play up front?
What is all-gig? software? a plug-in device?
where do i get this?
sorry for the dumba$$ questions.
Old Jun 26, 2009 | 01:38 AM
Bboyg's Avatar
Bboyg
Did you run an RCA cable for the camera all the way from behind the radio to the tailgate? How long of a cable did you use? Also what did you tap the power wire into?
Old Jun 26, 2009 | 02:45 AM
Smile's Avatar
Smile
yes...if you get the allgig or lockpick...this allows you to watch tv in the front and an extra outs for video for future back seat monitors and backup camera and also allows you to enter into the nav while in motion
yes it is plug and play
yes it is software
allgig is from navtv.com
i just one and will be installing it next week. i've done this with other vehicles in the past and it has worked flawlessly and worth every dollar.
Old Jun 26, 2009 | 02:47 AM
Smile's Avatar
Smile
did u drill out the hole? if so how did u do it without melting the plastic and it usually gets hot from the drill?
Old Jun 26, 2009 | 09:46 AM
hawk570's Avatar
hawk570
The all-gig is a device that plugs in between the radio and the harness. You will need about 35FT of cables and the hole can be drilled out, it's on my the plastic on the handle. I used a dremel tool,
Old Jun 27, 2009 | 12:33 AM
72combo's Avatar
72combo
slow down the drill speed it's plastic you could probably drill the hole my hand with the drill bit in plastic.If you can drill from inside and put the outside flat part on piece of wood, drill slow and you might have to file some burrs off if you go too fast, or even use a hole saw the exact size you need, that is what I would do.
