4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Ok so l got the RAM badges off with no problem.But l can't get the glue off!! Tried ronson lighter fluid,wd-40,tar and bug remover,and the hair dryer.Got most of it off with the hair dryer and rubbing till my fingers were blistered,but theres still a layer of glue,mostly the M. Any secrets to get this off would be much appreciated.Thanks
Everyone in the post has named something that will work. Goo Gone is your friend. Spray it on thick, let it soak in the glue...and literally within a minute or two u can take a nice sponge or rag and it should be able to rubbed off.
Hair dryer and fingers, no wonder you are blistered
I used something similar to goo gone.
I found the side which was in the shade while in 75 degree weather came off MUCH easier than the sunny side. The shaded side I almost pealed the double sided tape stuff off in complete lettered chucks.
