Multi Displacement Question,(MDS) 09 ram laramie
Old Aug 14, 2009 | 04:18 PM
TheDeuce's Avatar
TheDeuce
Default Multi Displacement Question,(MDS) 09 ram laramie
Alright, I have a new 2009 dodge ram 1500 laramie, and i am not a fan of the Multi Displacement System (MDS), and im not worried about gas, so is there any way I could take it off or turn the mds off. I basically have to floor it to get out of 4 cylinder mode and i would really like to be running 8 cylinders all the time. Hope you guys can help!
Old Aug 14, 2009 | 04:46 PM
topgun's Avatar
topgun
Have never heard of having to floor it to get out of the MDS mode. Something is wrong if that is the case. What make you think that it is staying on? Do you have the indicator? Mine kicks out very easily when you give it a tiny bit of gas. Works pretty seamlessly.
You can put the truck in "Tow Haul" mode and it will be turned off.
Old Aug 14, 2009 | 05:01 PM
cpelton's Avatar
cpelton
ya.. something sounds wrong there.... mine is seamless. The programmers coming out will be able to disable it
Old Aug 14, 2009 | 06:35 PM
jimf5's Avatar
jimf5
Hi All:
I am retired now, but when I worked I had a sign in my ofice that said " The least used of mans senses is COMMON". Why would you not want to ride around on a 145 HP engine at 1/3 less money(GAS) and be able to blow off most trucks, and quit a few cars, just by stomping on the gas pedal?
jimf5
Old Aug 14, 2009 | 06:48 PM
TheDeuce's Avatar
TheDeuce
Default umm
like i said before, i dont care about gas, it isnt a problem for me, just want to get rid of mds and be running my full 450 hp with the mods i put in.
Old Aug 14, 2009 | 07:08 PM
Doc Fluty's Avatar
Doc Fluty
what mods you plan on getting to get an extra 60 hp out of this engine?
Old Aug 14, 2009 | 07:41 PM
Ironsides's Avatar
Ironsides
Do you understand how a gasoline engine works?
An engine only puts out maximum horsepower when it's under full load, i.e. you'd have to be flooring it all the time. When you're just cruising around town, you're nowhere near full load, you're probably putting out around 1/4 of the max output. That's true of any naturally aspirated engine, in any vehicle.
The MDS will shut down half the cylinders under low load conditions, saving gas. You may not be concerned with fuel savings, that's fine, but if you turn off the MDS you will see no benefit, it's just physics. You'll be needlessly wasting fuel.
Old Aug 14, 2009 | 08:46 PM
plumcrazy73's Avatar
plumcrazy73
if you were building a drag car or a full race car and actually racing it I could see doing this but on a driver WHY?
Old Aug 14, 2009 | 09:09 PM
72combo's Avatar
72combo
Cuz he wants to and so might I, would be nice to have it in the EVIC, MDS on or off also the torque convertor management system would be nice to shut off.
I am with you I didn't buy this truck expecting to save gas, I just liked the suspension, ride, quietness, interior, 3 things i don't like, chrome clad anything, too high off the ground,the Hemi should look more impressive not a maze of ugly plastic tubes and boxes.
Oh ya the RAM badge should be smaller or on the pavement not the truck.
Old Aug 14, 2009 | 11:06 PM
k71000's Avatar
k71000
Ok.....so why did yu guys buy the ram? Should of got a Ford!
