Ticking
Old Sep 10, 2009 | 12:11 PM
danno5069's Avatar
danno5069
Default Ticking
My 09 Ram sport crew 5.7 has 1000 kms on it, after running 10 to 15 minutes I can hear a ticking sound coming from side of engine thru wheel well. Dealer said it is hemi noise mechanical top end, i think it is an exhaust leak. Any ideas.
Old Sep 10, 2009 | 02:55 PM
ran jr's Avatar
ran jr
Hard to say without hearing it in person but a lot of newer vehicles have valvetrain noise due to the thin oil being using. I wouldn't worry about it as long as the dealer will warranty it if it breaks.
Old Sep 10, 2009 | 03:22 PM
renos09's Avatar
renos09
I have two 09 rams that both have it. I hate it but it seems to be normal according to them.
Old Sep 10, 2009 | 03:30 PM
sking's Avatar
sking
I have two 09s and mine dont do it. I did have a tick with full synthetic oil so I pulled it out after 500 miles and it went away. At that time I decided not to use a full synthetic oil again.
Old Sep 10, 2009 | 05:10 PM
TheRiz's Avatar
TheRiz
Default ticking
My 09 Hemi ticked like crazy after putting amsoil 5w20 in it,toothin.now using m15w20,no ticking.
Old Sep 10, 2009 | 05:15 PM
hounddogg's Avatar
hounddogg
I use Amsoil 5w20.I hear nothing unusual.Apparently HEMIs do tick some.Read somewhere that the PCV is also noisey in them.
Old Sep 10, 2009 | 06:49 PM
lowriderman1225's Avatar
lowriderman1225
you know your MDS will not work with 15W20 right.
Old Sep 10, 2009 | 11:18 PM
Brummo's Avatar
Brummo
It will work, but it may not work correctly from what I am told.
Old Sep 11, 2009 | 01:03 AM
renos09's Avatar
renos09
I think he meant to say Mobil 1 5w 20 and forgot to put the space between the 1 and 5.
Old Sep 11, 2009 | 09:58 AM
T_Kizzle's Avatar
T_Kizzle
I'm not sure if your ticking problem was the same as mine, however, my truck started ticking real bad. It ended up being that the chrome mopar nerf boards I had were too loose. They tightened it and it stopped but then it sounded like they were going to break anytime I stepped on them. They installed a bushing kit for them and it stopped. Not sure if you have the same running boards, but you never know.
