Bluetooth Issue
My blue tooth is excellent. I have had my truck in the yard, with the music playing while I was cleaning it one day, walked inside to get a drink and the phone picked up from over 30 feet away. It always connects to my i phone with no problems right after I stick the key in.
I just wish the unit did Bluetooth stereo audio like the Ford Sync units have. That would be the ticket for streaming Pandora from my Blackberry. No wires!
Mine worked fine up to a couple of weeks ago. I'm due for an oil change, I'll just have them check it out along with checking for that thump in the rear that sounds like a ball is rolling in the bed, the trans disengagement at highway speeds, and maybe my seat cover that was ordered in July might be in.
So, what is required to activate the UConnect on the REQ radio package. The buttons are all there and I assume I would need to either replace the mirror with a mic unit or get a remote mic attachment.
My vehicle is an '09 Dakota with the Laramie Pkg grp. It seems to be a bit of an anomaly in Canada so I am still unsure what options are actually available on this set-up.
Thanks. GTFA
Thanks. GTFA
I believe this is true for the REN. Reading the ugly details about how hard it is to swap an REN (non-nav) for an RER (Nav), one of the main issues in the upgrade is U-Connect. The RER actually has the UConnect module built in to the radio, so as part of the upgrade, one of the two UConnect modules needs to be disabled as you can't have two UConnect systems in a single vehicle.
Does anybody have issues with some phones not hanging up when you drop the Bluetooth connection? Same truck different phone, no problem. However, the HTC Touch Pro 2 refuses to hang up (basically it sits in my cup holder continuing to let the other person listen to everything going on in the truck until I remember to pick it up and hang up, at which time the Bluetooth connection comes back up, silences the radio and sits there with a blank screen even though the phone isn't doing anything). I have the REN (Non-Nav) radio with the latest MyGig release. However, I have tried pairing the same phone in a friends truck (same year), though he has the RER (Nav) head unit with built-in UConnect module, and it works flawlessly.
Does anyone else have issues hanging up after a call??
