4x4 shutter
Old Oct 29, 2010 | 10:55 PM
  #41
renos09's Avatar
renos09
Do you have a lift kit installed?
Old Oct 30, 2010 | 01:00 PM
  #42
Jason.dil's Avatar
Jason.dil
no i do not have a lift kit.
Old Oct 30, 2010 | 04:04 PM
  #43
section88's Avatar
section88
wow. my early build 09 is as smooth as a prius. i put after market rims on and these tabs on the lugs that hold the rotors back caused problems. had to remove them and dremel the back of the holes on the rims to fit over the swell in the lugs where the threads ended 1/16" out of the rotor. maybe these problems are in relation to these rim/ rotor tab combos. mine shuddered before fixing that. you make me feel guilty for having such a perfect truck, best ever owned, when you have the same and hate it.
Old Oct 31, 2010 | 01:20 PM
  #44
Jason.dil's Avatar
Jason.dil
hey man thanks for the tips that could be the problem. I do have 305 tires on with 1/4 inch spacers so the wouldn't rub.
Old Oct 31, 2010 | 01:28 PM
  #45
Jason.dil's Avatar
Jason.dil
i do like the truck just been having bad luck man. It goes in the shop next week to get fixed up, i got hit with hail BAD last month and has 15 grand damage all over the truck.
