4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
don't have the part number handy.. I ordered it 2 weeks ago. should be here this week.
$205 CDN with bezel. When I have it I'll post the P/N from the receipt
That's what I have but it is very inconvenient under the dash. I do hit mine with my leg. And it is too much of an odd size to mount in the pocket on the left and looks like crap there. The Hayes G2 which is the same type of controller looks like it would be a better fit if you would intend on mounting it in the pocket.
I would rather deal with an inconveniently mounted Porportional brake controller than a cheap mopar time delay controller that sucks in comparison when it comes to safety and perfoemance. Cheaply made and overpriced to have a flush mounted so-so brake controller.
I suppose if you use it twice a year then it's fine, but for an avid user....go beyond the factory controller.
Doesn't have to be a Prodigy or mounted under the dash.....lol
looking forward to this, be sure to let us know how it works out!
We don't even know if it will work in a 2010 without a flash of some kind. As mentioned in the past threads, the Ford controller install needs a flash to make it work and the GM's cannot be added at all.
I just picked up my 2010 and it had the class 4 hitch with 4/7 pin connector in back installed from the factory. I went under the dash hoping to plug my controller in but don't see a blue plug anywhere. Had an 04 and 07 so know what it looks like. Anyone know if its different? Dealership had no idea.
anybody with a 2010 find where this harness is under the dash, can't see it anywhere, dealer said it was there with the pig-tail for the brake controller---what gives here ???
