airlift 1000 clunks
Old May 14, 2011 | 12:42 PM
09RuffRam's Avatar
09RuffRam
mine clunks as well, its recently been on my hitlist of things to look into cause its been driving me nuts. glad this came up and i might just take the noise for what it is and live with it
Old May 14, 2011 | 01:11 PM
Boo Radley's Avatar
Boo Radley
common and it does not cause any problem just annoying. seen about a half dozen trucks with the new inside the coil bags when i was working at the dealership. they all clunked whether they were name brand or ebay kits.
Old May 15, 2011 | 11:35 AM
jayman84's Avatar
jayman84
I have started running 15 to 20 psi in my bags all the time and I don't notice a clunk at all with mine. And at 15 psi I don't notice any difference in ride quality
Old May 22, 2011 | 10:17 PM
yotaman96's Avatar
yotaman96
Originally Posted by jayman84
I recently changed from the firestone bags to the airlift ones since my firestone ones blew out in the winter and I can tell you that the firestone bags are no taller than the airlift ones.
The older airlift bags were shorter with larger spacers.
Old May 23, 2011 | 01:12 PM
The Craig Machine's Avatar
The Craig Machine
I didn't know they changed the design. So the new Air Lift bags are taller with smaller spacers? Are they small enough to fit through the coil without having to take the coil out? If this is the case, I think I am going to order a new set. After taking out my old ones they are warped and indented from the coil. I would have to get them in there and line them up exactly the same.
Old May 23, 2011 | 01:26 PM
yotaman96's Avatar
yotaman96
Yes, the new ones can be done without taking the spring out. Just make sure you don't get some that have been sitting on the shelf somewhere for a long time. FWIW, mine were packed on 01/03/11 and are the newer style.
Old May 27, 2011 | 01:16 PM
chrisp929's Avatar
chrisp929
i have the old style .. i installed them in early '09 .. i also have the horrible clunk .. mainly on drivers side . makes me sick .. but i'm leaving them in .. maybe ill do the hockey puck mod one day when i have time .
I also get a clunk from the back of my seats and or seat belt system.
One noise is from the steel latches/cams that keep the rear seats from falling down during hard braking if your seats are folded up. They are located at the hinge and appear to be stainless steal. When i hit bumps, i get a clunky tink when they vibrate around in the hinge. I hate that .. also i get some kind of knocking noise from the rear seat belt retraction system . somewhere up top behind the plastic panel ..
i hate extra noises and this truck is starting to **** me off when it comes to noises ...
Old Jun 1, 2011 | 01:54 PM
The Craig Machine
Just finished installing the new and improved bags in my truck. Took a whole 45 minutes doing it by myself. Took me about 3 hours to install the old style, having to take the coil spring right out. A few weeks ago I installed the Firestone bags on my father in laws Avalanche. The new Air Lifts are exactly the same as the Firestone bags now. Those of you with the old style, I highly recommend spending the $100 or so and getting the new style. In my opinion it is well worth getting rid of that annoying clunk, drove me nuts.
Old Jan 5, 2014 | 08:44 AM
Ti-Moose's Avatar
Ti-Moose
Does anyone have pics with an atv in the box before & after install ? that would be great Thanks
