Lost my oil drain plug....messy.....Long read!
Old May 20, 2010 | 10:28 PM
  #21
72combo's Avatar
72combo
Somebody gonna get a spot in the unemployment line. That is like the one of the two most things u should be careful about...that and oil in the crankcase. Unbelievable. I think that kind needs training.
Old May 21, 2010 | 03:01 PM
  #22
soad's Avatar
soad
Originally Posted by RAMULAK
In the back of m y mind I am thinking of trading it right now.
That's why I will never buy a used vehicle, the dealership will just sell the truck to some unsuspecting guy at a nice little profit and never tell him there was a problem. (not that the OP should worry about that, I would get rid of the truck right quick)
Old May 25, 2010 | 10:04 AM
  #23
RAMULAK's Avatar
RAMULAK
Default Update!
Sorry it has been a few days. Very busy me!
well I got the truck back. They had given me a loaner truck 2010 Sport.
Noticed a few things I'l point out later.
I went to the dealer and sat in theoffice while they desribed what they found. Basically nothing. They borescoped each cylinder and pulled the valve covers to look at the camshafts I guess. Found no scoring or galling. Put it back together and handed me the keys. I asked about what would happen if something went wrong again? they told me I am still covered under the Manufacturers lifetime power train warranty for as long as I own the vehicle.
I made sure to get a copy of the work performed and the reason why stated on the form. Sometimes they can be vague in describing the reason for the work and I wanted it in plain writing that the plug had fallen out.
Now of course they did not admit to their guy not tightening the plug...because nowhere on the form does it say that.
So I have my truck back.....
Now something I noticed while driving the new 2010. It is louder in the cab than my truck. I don't know if anyone noticed this....
I have a professional decibel meter from my car stereo days, and measured the new truck on the same road at the same speeds in the same weather.
The new Ram was about 4-5 decibels louder at all RPMs, and my old truck has the Mufflex exhaust. So I would assume that my early '09 would be quite a bit quieter if it had the stock exhaust. Did they have more sound deadening material in the earlier trucks for some reason? Because aerodynamically they are pretty much the same.
With the drivers window down at 40mph I get 101db, in my truck. I did not measure window down in the new truck.
I also noticed it shifts slightly sooner on the new truck. Mine stays in first longer when at full throttle.
Anyway just a couple of things I noticed different.
Old May 26, 2010 | 09:48 AM
  #24
Coolidge's Avatar
Coolidge
The first place I would look for damage would be the cam and crank shaft bearings which are soft and require oil pressure. In other words I call BS on this dealer inspection.
Old May 26, 2010 | 12:40 PM
  #25
72combo's Avatar
72combo
I said this in another post I thing the early build 09's have extra lets. call it padding. I was gonna put fat mat in the doors but its there, and tons of insulation. The doors when they close have that nice sound like a luxury car front AND back doors. I think they experimented with these trucks or were the ones that the Award companies got to look at? Who knows, all I know is mine is super quiet. My wife and I went to a drive thru and sat in the truck parked facing and 4 lane road at rush hour and could only hear trucks, and loud Harleys we had the radio on but low just right. Between the insulation and the radio we could block out all sounds.
Old May 31, 2010 | 02:03 AM
  #26
RamPhreak's Avatar
RamPhreak
Default 2009 Lifetime Warranty Planning
This story is everyones nightmare. At least it happened close to home and was caught quickly it appears. Hopefully it didn't leak all out first then come out causing damage. Good luck with it.
