Getting power from the reverse lights?
Old Jun 7, 2010 | 12:32 PM
nick bourgeois's Avatar
nick bourgeois
Default Getting power from the reverse lights?
I recently installed the recon reverse lights on my truck, and im not getting power to them when i put the truck in reverse. the toggle switch works only. i have a relay, that i think is bad, But my questions is. If i splice into the reverse wires ( white with a red stripe) i should get power uh? I know some splice into the 7 pin wiring harness for stuff like this, but i have done it already.
Old Jun 7, 2010 | 02:03 PM
rolltidehemi's Avatar
rolltidehemi
check your fuse box first for blown fuse
Old Jun 7, 2010 | 05:55 PM
nick bourgeois
my reverse lights still work from the factory, when in reverse
Old Jun 7, 2010 | 09:50 PM
rolltidehemi
yeah you should get power, and its on a separate fuse than the 7 pin, I would use the 7 pin.
Old Jun 8, 2010 | 10:22 AM
jawsdc's Avatar
jawsdc
will the wiring schematic for the plug help?
http://moparestore.trademotion.com/m...s/K6869558.pdf
it's at the bottom of the PDF
good luck
(nevermind, it does not have the brake lights listed, lo siento)
Old Jun 8, 2010 | 02:10 PM
nick bourgeois
I have it working, Thanks for the help
Old Jun 9, 2010 | 10:31 PM
JRI's Avatar
JRI
What was the fix?
Old Jun 10, 2010 | 07:01 PM
nick bourgeois
I had the diao the wrong way. The picture showed one way, but instructions said a different way and i had everything sealed and taped, so i had to un tap eveything
