Towed 700 miles today, my thoughts and opinions!
Old Jul 15, 2010 | 03:24 PM
  #21
Mopar21277's Avatar
Mopar21277
Originally Posted by USAF1
I have a mtn cabin at 5200 ft. Going up there from the valley in which I live gets a little steep and I noticed that trans temp climbs to 205 degrees F, and that is in tow/haul mode and manually shifted down into 3rd gear running around 2300 rpm. Someone in an earlier post to this thread said that trans fluid breaks down around 200 degrees F. Is this really true?? If so, what am I supposed to do? Shift down into 2nd maybe to get the rpms even higher? Tx.
The thing to do is to not play with the EVIC info and not worry too much or overthink it... We went for years and years with this tranny without a digital temp reading and were just fine.
Old Jul 15, 2010 | 03:31 PM
  #22
Mopar21277's Avatar
Mopar21277
Originally Posted by Revo
That makes more sense.
That is interesting...if the tranny has 6 gears, why not just make the gear ratios more of an even split across all 6 gears and have it be a 6 speed transmission?
We'd be able to tow like a 3.92 and get the highway mpg of a 3.21...
Amen dude, this "old" tranny (10 yrs) was my only hesitation in buying the '10, coming from an '05. Wow, they did a great job with the shifting logic, it is a whole new beast.
The ideal setup would be a true 6 spd, ala ford, something like:
1- 3.67, 2- 2.50, 3- 1.45, 4- 1.00, 5, 6 o/d
My suspicions is that for the new engine in 2012, they will have a 7spd auto, something like Mercedes has, with 5 gears to 1:1 and 2 O/Ds.
Old Jul 15, 2010 | 04:32 PM
  #23
05Dakotaho's Avatar
05Dakotaho
Perhaps I misled you about the 200 deg oil breakdown.
Here is the chart I referenced. Hope this helps.
Old Jul 15, 2010 | 05:27 PM
  #24
BigBlueEdge's Avatar
BigBlueEdge
You'd want to make sure that chart applies to ATF+4 before giving it credence for our RAMs. ATF+4 is a synthetic trans fluid that is supposed to have high temp capabilities. I don't know the specifics, but it is likely better rated than non-synthetic.
Rob
