Swapping gears, from a 3.21 to 3.92
Old Sep 28, 2010 | 01:51 PM
smokinjoe72's Avatar
smokinjoe72
Default Swapping gears, from a 3.21 to 3.92
The truck I WAS going to buy was sold the day before I went to pick it up, so I bought a cheaper 2010 with 3.21's knowing I'd have to swap it out later.
Today I found a set of 3.92s from a 2010 at a salvage yard and this is what I pulled. Cost $260
I have no idea if this diff includes the LSD or not. I assume since its not sealed it doesnt or dodge uses helical maybe?
My question is should I still buy the $125 master install kit with the shims, etc or should it bolt right in. Granted I'll still paint the gears and check for clearance and use a backlash gauge.
Any help is appreciated.
Old Sep 28, 2010 | 02:16 PM
05Dakotaho's Avatar
05Dakotaho
It should be an LSD. Look inside the carrier and you will find the friction clutches between the spider gears and the carrier housing.
Probably a good idea to get the master install kit. Most pro installers won't install without it.
Here is an excellent link with photos re install tips:
http://www.*********.com/forums/show...10#post3338310
oops, this forum will not allow the link, I'll try to PM you with it.
Old Sep 28, 2010 | 02:26 PM
smokinjoe72
Can you email me the link? It was redacted by the forum. ippolitofamily at gmail dot com
Thank you!
Old Sep 28, 2010 | 02:45 PM
05Dakotaho's Avatar
05Dakotaho
done....
Old Sep 28, 2010 | 03:12 PM
BULLRAM's Avatar
BULLRAM
Turn the diff sideways and take a picture, first there is NO tone ring on there, that makes me think that is an older rear, unless someone took it off, a 2010 would have an AUBURN in it and not a trac-loc if it is an LSD
Old Sep 28, 2010 | 03:41 PM
smokinjoe72
Bull, can you explain what I should be looking for? I had this pulled from a 2010. All 4gen 3.92 LSDs are from Aurburn and non-lsd from Trac-loc? They better have pulled it from the new truck.
Old Sep 28, 2010 | 04:11 PM
HEMI_ROM's Avatar
HEMI_ROM
Talking
Man are you gonna be happy going from 3:21 to 3:92
Old Sep 28, 2010 | 04:17 PM
ilandaze2's Avatar
ilandaze2
did you just call different salvage yards to see if they had one?
Old Sep 28, 2010 | 04:27 PM
smokinjoe72
I got lucky and found one with 17K miles, no rear end damage. But yea, called around.
Old Sep 28, 2010 | 06:47 PM
706jim's Avatar
706jim
Silly question, but is your truck 2WD?
