Bilstien Height Adjustable Shocks
Old Dec 24, 2010 | 10:24 PM
BigWave's Avatar
BigWave
Originally Posted by andy78
got any pics? And what height did you set them at? Im still debating on whether or not to get them..
I dont have any pics yet. I will try and get some in the next day or 2. I set them at the highest setting (2.8"). I really like the way it looks like it is. It also rides fantastic. Still unsure if I'm going to put the Ready Lift rear kit on.
Old Dec 25, 2010 | 09:30 AM
ct1's Avatar
ct1
Default re: bilistein shocks
Did you put them on yourself and was it easy? If you wanted to lift the rear end would you throw a set of those on the back and just not raise them as much?
This is the first that I have seen of these and it does look very interesting to me especially if it is a do it yourself project.
Can't wait to see the pictures.
Thanks.
Old Dec 25, 2010 | 02:24 PM
BigWave's Avatar
BigWave
While I could have done it and have in the past, I had a friends shop do it down the street. It does require a coil spring compressor to install. I did the set on my old truck (07 Tundra). It was a pain in the tail, but I did it. Buddys shop has a huge coil spring compressor that takes seconds to do, versus the little POS compressor that I used last time. He charged me $100 to install them. Well worth it to me.
If I do decide to do the rear I will for sure do those myself. The rear is just spacers that go on top of the coils so no spring compressor is needed. Just jack it up, unbolt the trackbar and sway bar links, lower the rear end a bit and you're good to go.
The Bilstien lift setup is only available for the fronts so you will need to figure out another source for your rear lift. I called the folks at Ready Lift directly to buy the rear. I could only find their complete F/R set available from most of the 4 Wheel places online. Ready Lift sold me the rear set with no problems and had it to me within a few days.
Old Dec 25, 2010 | 06:58 PM
BigWave's Avatar
BigWave
Here's a couple pics!
Attached Thumbnails Bilstien Height Adjustable Shocks-trk1.jpg   Bilstien Height Adjustable Shocks-trk2.jpg
Old Dec 31, 2010 | 10:31 AM
Nashram's Avatar
Nashram
Nice looking ride Big,I'm thinking of getting these also.Do these mess with the factory warranty,or are they OK?My truck only has 175 miles on it,would hate to void anything.
