transmission shudder
Old Feb 23, 2011 | 09:48 PM
HEMI2500TRX4's Avatar
HEMI2500TRX4
Default transmission shudder
I have a 2010 ram 2500 with the hemi. I have experienced on several occasions a real lazy downshift. Almost a studdering shaking stumbling sensation. Then most recently today while towing it didn't want to downshift and i could hear like a metal on metal grinding/groan. Has anyone else experienced this.
Old Feb 23, 2011 | 10:50 PM
InterpunX's Avatar
InterpunX
How is it holding up now, still feels like its normal or its always acting up? What type of transmission is in your truck?
I know some people are having some issues with shuttering, but mostly with a tuner installed.
Old Feb 24, 2011 | 08:59 PM
HEMI2500TRX4
It got me to my hotel. I won't know anything further until the return trip home. It's a 5 speed ram 2500 hemi.
Old Feb 24, 2011 | 10:02 PM
Revo's Avatar
Revo
If I'm not mistaken the 2500's have 6 speeds...
Old Feb 24, 2011 | 10:30 PM
InterpunX's Avatar
InterpunX
The cummins has the 6 speed but the 2500 hemi i believe has the same tranny as the 1500.
Old Feb 25, 2011 | 09:53 AM
devile's Avatar
devile
It's happened to me twice over the last 8000kms or so. For those of you who are familiar with older veh's. It feels like a transmission kick-down cable has been stretched. I understand these trucks don't have that, but it's the best way I can describe it along with HEMI2500TRX4 description.
I was going to take it to the dealer, however, I can't recreate it on demand, and no code is thrown, so they'd likely just send me on my way, and waste everybody's time.
Old Feb 25, 2011 | 10:08 AM
jball's Avatar
jball
I had it happen once, it was when going up a small hill holding a constant speed. It felt like it was unsure what gear it wanted (or torque converter lock/unlock repeatedly extremely fast), I left off the gas and bumped the manual shift control down a gear (to 4th) and it instantly corrected it. Several months later I had a solenoid in the trans go bad (would go from 1st to 4th gear)... replaced under warranty. No clue if it is related or not?
Old Feb 25, 2011 | 10:33 AM
HEMI2500TRX4
R
That is correct only the diesel has the 6 speed. I don't know if the 2500 and 1500 transmissions are identical, but they are both 5 speeds when equipped with the hemi.
Old Feb 25, 2011 | 12:25 PM
InterpunX's Avatar
InterpunX
Did you ever have an engine light or code come up when your selenoid went bad. Im having the same issue with the torque converter locking/unlocking repeatedly and it threw the P0742 code (torque converter clutch selednoid stuck open)
Truck is at the dealership now hopefully they find the problem.
Old Feb 25, 2011 | 01:40 PM
jball's Avatar
jball
When the solenoid went out, the light came on and it was a P code (don't remember which one, it was half a year ago). They figured it pretty quick at the local dealership. Had it back in 2 days.
