Old Aug 5, 2015, 08:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
key fob problems
Old Mar 24, 2011 | 11:12 AM
jawsdc's Avatar
jawsdc
Originally Posted by dizzyttc
When I get a chance I,ll see if the dealer put any codes for replacing the remotes on the work order. This was done at my dealer in Toronto.
Thanks Dizzy!
and as always, combo72, we appreciate the constructive advice. your contributions on this site are invaluable.
Old Mar 24, 2011 | 11:02 PM
volunteer's Avatar
volunteer
Originally Posted by jawsdc
Thanks Dizzy!
I'll bet he has a fascinating newsletter you could subscribe to.
Old Mar 24, 2011 | 11:29 PM
dizzyttc's Avatar
dizzyttc
This is on my invoice. 10575 intermittent/short range of fobik 08804401 replaced and reprogrammed both fobiks. Hope this helps.
Old Mar 25, 2011 | 10:54 AM
jawsdc's Avatar
jawsdc
thanks again Dizzyttc, i'm sure those numbers will mean something to those in the know.
Old Mar 26, 2011 | 04:23 AM
TDTIPMO's Avatar
TDTIPMO
I wasn't aware that they were swapping out fobs. That's good to know. Sometimes mine doesn't work and I have to fiddle with it for a few seconds before it decides to do anything. I'll have to check with the dealership when I get back and see what they can do for me.
Old Feb 28, 2012 | 10:05 AM
Adirondaker's Avatar
Adirondaker
Default Defective Ram keyfobs
Hope this helps: My fobs both had issues working intermittantly after probably 2-3 weeks of use on my new 2011 Ram. My dealer claimed there were no tsb's from Dodge on this. They initially did not replace my remotes. I replaced the batteries in both with the same issues surfacing again in 2-weeks. I popped the fobs apart & noticed 4 minute (possibly burn or corrosion) marks where the 4 pointed contacts touch the battery from the circuit board.I rotated the battery slightly & all worked well again for another 2-3 weeks. I brought this to my dealers attention & only now they are replacing both remotes...
Old Feb 28, 2012 | 10:24 AM
DodgeCares's Avatar
DodgeCares
All,
I have found a TSB involving a flash to the WIN module on the 2010 and the 2011 regarding the RKE (remote keyless entry) not working intermittently. I have posted both TSB's below. Sorry, but I could not find anything for the 2009 models.
NUMBER: 08-024-11 REV. A
GROUP: Electrical
DATE: July 01, 2011
SUBJECT:
Flash: Intermittent No Start Or Intermittent RKE Function
OVERVIEW:
This bulletin involves flash reprogramming the Wireless Ignition Node (WIN) with new
software.
GROUP: Electrical
DATE: July 01, 2011
MODELS:
**2011 (DD) Ram 3500 Cab Chassis**
**2011 (DJ) Ram 2500 Pickup**
**2011 (DP) Ram 4500 / 5500 Cab Chassis**
2011 (DS) Ram 1500 Pickup
**2011 (DX) Reg Cab Chassis (Mexico)**
2011 (LC) Challenger
2011 (RT) Caravan / Town & Country
2011 (W2) Grand Cherokee (CKD)
2011 (WD) Durango
2011 (WK) Grand Cherokee
NOTE: This bulletin applies to **DD, DJ, DP, DS, DX** vehicles built before April 7,
2011 (MDH 0407XX) equipped with Remote Keyless Entry (Sales Code GXM).
NOTE: This bulletin applies to LC, W2, WD, WK vehicles built before April 7, 2011
(MDH 0407XX).
NOTE: This bulletin applies to RT vehicles built before April 12, 2011 (MDH 0412XX).
SYMPTOM/CONDITION:
The service flash corrects the following conditions:
· Intermittent no start
· Intermittent RKE function
The above conditions may be caused by a software lockup in the module. The lockup
condition may be cleared by removing and reinserting fuse M27.
Flash reprogramming the WIN will correct these conditions.
DIAGNOSIS:
Verify that the Wireless Ignition Node is functioning as designed. If DTC's are present,
record them on the repair order and repair as necessary before proceeding further.
If a customer’s VIN is listed in VIP or your RRT VIN list, perform the repair. For all other
customers that describe the symptom/condition, perform the Repair Procedure.
NUMBER: 08-010-10
GROUP: Electrical
DATE: May 14, 2010
SUBJECT:
Flash: WIN Module For Intermittent RKE Functions
OVERVIEW:
software.
MODELS:
2010 (DS) Ram Truck 1500
2010 (JC) Journey
2010 (LC) Challenger
2010 (LE) International 300 or Charger
2010 (LX) 300 and/or Charger
2010 (WK) Grand Cherokee
2010 (WH) International Grand Cherokee
2010 (XK) Commander
2010 (XH) International Commander
SYMPTOM/CONDITION:
Customer may experience intermittent FOBIK operating characteristics. Dealers are
required to verify the manufacturer of the Wireless Ignition Node Module (WIN) and if
necessary, Flash the WIN with updated software.
Old Feb 28, 2012 | 01:47 PM
Ironhead's Avatar
Ironhead
you do realize this post is almost a year old
Old Feb 28, 2012 | 01:53 PM
DodgeCares's Avatar
DodgeCares
Ironhead,
I did realize that but I figure if this poster was looking maybe others will look here as well now that a post was made to it.
Old Feb 29, 2012 | 06:53 AM
Adirondaker
Default RKE Problem
Thanks so much,I will bring this to my dealers attention!
